Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
New Contributor II
Getting_setting_date and time on Edison
I have an active internet connection on the edsion, but when I enter 'date' I get a date and time that is over a week old. Why? Isn't the date and time always current?
Mon Mar 9 20:21:19 UTC 2015
Highlighted
Re: Getting_setting_date and time on Edison
not sure -
are you behind a proxy / firewall? do you use connman for network? (has a built-in lightweight ntp daemon)
Highlighted
New Contributor II
thanks. no firewall that I know of. Isn't it possible to simply set the date using
$ date MMDDHHMMSS
Highlighted
sure - apart from the syntax would be slightly different (e.g. http://linux.die.net/man/1/date date(1): print/set system date/time - Linux man page).
And preferably via timedatectl
# timedatectl -h
timedatectl [OPTIONS...] COMMAND ...
Query or change system time and date settings.
-h --help Show this help message
--version Show package version
--no-pager Do not pipe output into a pager
--no-ask-password Do not prompt for password
-H --host=[USER@]HOST Operate on remote host
-M --machine=CONTAINER Operate on local container
--adjust-system-clock Adjust system clock when changing local RTC mode
Commands:
status Show current time settings
set-time TIME Set system time
set-timezone ZONE Set system time zone
list-timezones Show known time zones
set-local-rtc BOOL Control whether RTC is in local time
set-ntp BOOL Control whether NTP is enabled
However, the question why the date wouldn't be set automatically, right?
Highlighted
New Contributor II
ok came across another long thread on this topic
so when I enter
$systemctl status systemd-timesyncd
I get
root@tesla:~# systemctl status systemd-timesyncd
● systemd-timesyncd.service - Network Time Synchronization
Loaded: loaded (/lib/systemd/system/systemd-timesyncd.service; enabled)
Active: active (running) since Mon 2015-03-09 20:07:57 UTC; 13min ago
Docs: man:systemd-timesyncd.service(8)
Main PID: 156 (systemd-timesyn)
Status: "Idle."
CGroup: /system.slice/systemd-timesyncd.service
└─156 /lib/systemd/systemd-timesyncd
Jan 01 00:00:12 tesla systemd-timesyncd[156]: System clock time unset or jumped backwards, restoring fr... UTC
Mar 09 20:07:57 tesla systemd[1]: Started Network Time Synchronization.
Mar 09 20:08:02 tesla systemd-timesyncd[156]: Network configuration changed, trying to establish connection.
Mar 09 20:08:03 tesla systemd-timesyncd[156]: Network configuration changed, trying to establish connection.
Hint: Some lines were ellipsized, use -l to show in full.
Highlighted
hmmm, seems you have some issues:
Active: active (running) since Mon 2015-03-02 08:24:06 CET; 2 weeks 1 days ago
Main PID: 152 (systemd-timesyn)
Status: "Using Time Server 216.239.36.15:123 (time3.google.com)."
└─152 /lib/systemd/systemd-timesyncd
Jan 01 01:00:12 edison systemd-timesyncd[152]: System clock time unset or jumped backwards, restoring from recorded timestamp: Mon 2015-03-02 08:24:06 CET
Mar 02 08:24:06 edison systemd[1]: Started Network Time Synchronization.
Mar 02 08:24:10 edison systemd-timesyncd[152]: Network configuration changed, trying to establish connection.
Mar 02 08:24:11 edison systemd-timesyncd[152]: Network configuration changed, trying to establish connection.
Mar 17 17:02:35 edison systemd-timesyncd[152]: Network configuration changed, trying to establish connection.
Mar 17 17:03:05 edison systemd-timesyncd[152]: Using NTP server 216.239.36.15:123 (time3.google.com).
Mar 17 17:03:05 edison systemd-timesyncd[152]: interval/delta/delay/jitter/drift 64s/-0.025s/0.052s/0.000s/+0ppm
Mar 17 17:04:10 edison systemd-timesyncd[152]: interval/delta/delay/jitter/drift 128s/-0.006s/0.044s/0.002s/-23ppm
Mar 17 17:06:18 edison systemd-timesyncd[152]: interval/delta/delay/jitter/drift 256s/+0.014s/0.087s/0.009s/+4ppm
Mar 17 17:10:34 edison systemd-timesyncd[152]: interval/delta/delay/jitter/drift 512s/-0.005s/0.052s/0.009s/+0ppm
Mar 17 17:19:06 edison systemd-timesyncd[152]: interval/delta/delay/jitter/drift 1024s/-0.003s/0.045s/0.009s/-1ppm
Maybe try another time server?
# cat /etc/systemd/timesyncd.conf
# This file is part of systemd.
# systemd is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2.1 of the License, or
# (at your option) any later version.
# See timesyncd.conf(5) for details
[Time]
Servers=time1.google.com time2.google.com time3.google.com time4.google.com
Highlighted
New Contributor II
Also if I enter
$timedatectl status
I notice that NTP synchronized: no
Local time: Mon 2015-03-09 20:31:47 UTC
Universal time: Mon 2015-03-09 20:31:47 UTC
RTC time: Sat 2000-01-01 00:24:02
Time zone: Universal (UTC, +0000)
NTP enabled: yes
RTC in local TZ: no
DST active: n/a
Highlighted
New Contributor II
Ok narrowed the issue down to my edison configuration using connman to set a static IP.
If I revert back to default DHCP the time date is correct.
Can't seem to reach any time servers after setting a static IP using
$connmanctl config --ipv4 manual
Highlighted
you probably would need to manually set nameservers, default gateway ...
In connmanctl there are various settings:
(timeservers for connman internal time sync)
# connmanctl help
config Set service configuration options
--nameservers [] []
--timeservers [] [...]
--ipv4 off|dhcp|manual
In particular you should be able to ping a named address like "ping google.com"
if you install the connman-tests package you'd find some helpers which you might find of interest as well:
# /usr/lib/connman/test/test-clock
TimeUpdates = auto
Timezone = Europe/Paris
Timeservers = [ ]
TimezoneUpdates = auto
Time = 1426617841
# /usr/lib/connman/test/set-nameservers
Usage: /usr/lib/connman/test/set-nameservers [nameserver*]
