Hello Intel corporation
I am using Intel Edison Mini breakout board. I tried to boot Intel Edison from SDcard via a card reader. I folllowed this link .
In this way i have installed OS on Intel Edison
After this process .
my hardware setup is like this.
Below I have given my putty log while doing this process.
Sdcard = 32Gb, class10
Poky (Yocto Project Reference Distro) 1.7.3 RamishaEdison ttyMFD2
RamishaEdison login: root
Password:
root@RamishaEdison:~# dmesg |tail -n 10
[ 15.191435] wl_bss_connect_done succeeded with d0:17:c2:3b:11:0c
[ 15.259183] wl_bss_connect_done succeeded with d0:17:c2:3b:11:0c
[ 16.126652] ip (374) used greatest stack depth: 5096 bytes left
[ 20.228190] snd_intel_sst: Stop for str 14 pipe 0xe
[ 20.228596] snd_intel_sst: Free for str 14 pipe 0xe
[ 20.325380] snd_intel_sst: Stop for str 1 pipe 0x90
[ 20.325975] snd_intel_sst: Free for str 1 pipe 0x90
[ 20.328622] snd_intel_sst: runtime_idle called
[ 22.327021] snd_intel_sst: runtime_suspend called
root@RamishaEdison:~# dmesg |tail -n 100
[ 5.732422] usb usb2: Product: xHCI Host Controller
[ 5.732441] usb usb2: Manufacturer: Linux 3.10.98-poky-edison+ dwc-xhci
[ 5.732460] usb usb2: SerialNumber: dwc3-host.2
[ 5.733104] xHCI xhci_add_endpoint called for root hub
[ 5.733132] xHCI xhci_check_bandwidth called for root hub
[ 5.733408] hub 2-0:1.0: USB hub found
[ 5.733460] hub 2-0:1.0: 1 port detected
[ 5.796627] pmic_ccsm pmic_ccsm: USB VBUS Detected. Notifying OTG driver
[ 5.905394] systemd-udevd[142]: starting version 213
[ 6.049054] usb 1-1: new full-speed USB device number 2 using dwc3-host
[ 6.070304] usb 1-1: New USB device found, idVendor=05e3, idProduct=0606
[ 6.070337] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.070359] usb 1-1: Product: USB Hub 2.0
[ 6.070378] usb 1-1: Manufacturer: ALCOR
[ 6.075685] usb 1-1: ep 0x81 - rounding interval to 1024 microframes, ep desc says 2040 microframes
[ 6.117086] hub 1-1:1.0: USB hub found
[ 6.117276] hub 1-1:1.0: 4 ports detected
[ 6.286641] systemd-journald[115]: Received request to flush runtime journal from PID 1
[ 6.389005] usb 1-1.1: new full-speed USB device number 3 using dwc3-host
[ 6.410544] usb 1-1.1: New USB device found, idVendor=0d8c, idProduct=013c
[ 6.410575] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.410596] usb 1-1.1: Product: USB PnP Sound Device
[ 6.410616] usb 1-1.1: Manufacturer: C-Media Electronics Inc.
[ 7.031713] input: C-Media Electronics Inc. USB PnP Soun...
Hi Ramisha93,
Thank you for contacting us. We'll try to help you resolve this issue. There are a couple of things I noticed and that you can check out to see if you get different results. The first is that you're using a class 10 SD card. Some users have reported issues using this SD class type as can be seen here /message/389927# 389927 https://communities.intel.com/message/389927# 389927 . Is it possible for you to try using a different type of SD? Also, the guide you're following was made originally for the Edison image Release 2. Can you try to flash this Release and with a different SD class card try once again the procedure from /thread/61048 https://communities.intel.com/thread/61048 again? You can find a link to download Release 2.1 here http://downloadmirror.intel.com/25028/eng/edison-image-ww25.5-15.zip http://downloadmirror.intel.com/25028/eng/edison-image-ww25.5-15.zip .
We'll be waiting for your results.
-Sergio A
Nearly i tried so many times and now am currently working running python program on intel Edison. i have tried with usb stick too. I never tried with other sdcard. when i try i will eet know sir. My project submission is near. so I am trying to manage on emmc memory itself .
Thank u for your reply sir.
Hi Ramisha,
Thank you for your reply. Please keep us updated on your progress.
-Sergio A
Hi Ramisha,
Do you still need assistance with this case?
-Sergio A
