Community
cancel
Showing results for
Search instead for
Did you mean:
RHett
Gpio pins on intel edison
Jump to solution
I'm using the following code to light the LED connected to Digital Pin ~5 on my Edison. & it works (I'm using Arduino Expansion Board)
int main(){
mraa::Gpio* d_pin;
d_pin =new mraa::Gpio(5, true, false);
d_pin->write(1);
so in order to light the LED connected to Digital pin ~6 the modified code should be
int main(){
mraa::Gpio* d_pin;
d_pin =new mraa::Gpio(6, true, false);
d_pin->write(1);
right? but it doesn't work
can someone map out the digital pins with Gpio
RHett
I figured out the answer I need to put this piece of code
d_pin->dir(mraa::DIR_OUT);
RHett
