Community
cancel
Showing results for
Search instead for
Did you mean:
mmart35
Grbl cnc help??
so i am having trouble loading the grbl hex file to the new intel curie. It is not allowing me to load the file to it for some reason. im using xloader to transfer the file over and it says its uploading and is stuck on the uploading part. ive looked around for tutorials on how to do it but i havent found anything because of how new this version is i guess.... anyone have any suggestions??
Community Manager
Hi Solokhan,
Thank you for your interest in the Curie module.
To provide a better assistance, we would like you to ask some more questions about your situation.
  1. Which tutorial or guide are you using to setup your Arduino 101 board? We would like to check the steps you're following to see if there's anything that should be done different.
  2. What OS are you using to configure your board?
  3. Is the tutorial you're following tested on an Arduino 101 board?
We'll be waiting for your reply.
-Pablo
mmart35
http://blog.protoneer.co.nz/grbl-arduino-library/ these are the 2 links i have been going off of. But Im assuming the arduino 101 currie has completely different setup as to where going about installing grbl this way wont work. And i believe this has not been tested on the arduino 101 board by anyone else just yet. But i tried it myself with no success and im running this all on windows 10
https://github.com/grbl/grbl/wiki/Flashing-Grbl-to-an-Arduino https://github.com/grbl/grbl/wiki/Flashing-Grbl-to-an-Arduino
Community Manager
Hi Solokhan,
Yes, I checked that as well and it hasn't been tested with any platform based on the Curie module, including the Arduino 101. Given the differences between the Atmel processor from the standard Arduino boards and the Atom, in which the Curie module is based, it is not likely that it will work with the Arduino 101 platform.
In any case, you can keep trying to make it work and share your updates with the Community.
-Pablo
