Intel® Makers
9882 Discussions
Grove GPS via Arduino IDE
Community Manager
(Message updated with TinyGPS)
I connected my GPS module (SIM28) to the UART port on the Grove only to find that SoftwareSerial doesn't work in the Arduino IDE. Looking around, I found discussions that either led on a wild goose chase or provided lengthy references to wade in.
So for sharing, you will find below my basic Grove GPS sketch that works well with TinyGPS - you can get the TinyGps files from https://github.com/mikalhart/TinyGPS here. Download them and place Tinygps.cpp and Tinygps.h in the same folder as this sketch. (The sketch is based off simple_test.ino found in the Github repo). The most important lines that gets this working on the Intel Edison is found on lines 3, 4, 9, 10, 22, and 23; the rest of the code is similar.
If you want to find out more about RingBuffer and TTYUARTClass, head over to this folder on your computer -
"\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\cores\arduino" and look up Ringbuffer.cpp and TTYUART.cpp
# include "TinyGPS.h"
RingBuffer rx_buffer_GPS;
TTYUARTClass SerialGPS(&rx_buffer_GPS, 1, false);
TinyGPS gps;
void setup() {
SerialGPS.init_tty("/dev/ttyMFD1");
SerialGPS.begin(9600);
Serial.begin(9600);
Serial.println("Begin!");
void loop() {
bool newData = false;
unsigned long chars;
unsigned short sentences, failed;
for (unsigned long start = millis(); millis() - start < 1000;)
while (SerialGPS.available())
char c = SerialGPS.read();
//Serial.write(c); // uncomment this line if you want to see the GPS data flowing
if (gps.encode(c))
newData = true;
if (newData)
float flat, flon;
unsigned long age;
gps.f_get_position(&flat, &flon, &age);
Serial.println();
Serial.print("LAT=");
Serial.print(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flat, 6);
Serial.print(" LON=");
Serial.print(flon == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flon, 6);
Serial.print(" SAT=");
Serial.print(gps.satellites() == TinyGPS::GPS_INVALID_SATELLITES ? 0 : gps.satellites());
Serial.print(" PREC=");
Serial.println(gps.hdop() == TinyGPS::GPS_INVALID_HDOP ? 0 : gps.hdop());
gps.stats(&chars, &sentences, &failed);
Serial.print("CHARS=");
Serial.print(chars);
Serial.print(" SENTENCES=");
Serial.print(sentences);
Serial.print(" CSUM ERR=");
Serial.println(failed);
if (chars == 0)
Serial.println("** No characters received from GPS: check wiring **");
And here is the sample output observed while outdoors:
$GPGGA,015116.000,0122.6789,N,10351.3328,E,1,4,16.26,131.8,M,4.0,M,,*5B
$GPGSA,A,3,26,03,16,22,,,,,,,,,22.12,16.26,15.00*36
$GPGSV,4,1,13,16,65,313,11,27,48,168,14,26,46,003,10,22,44,282,11*74
$GPGSV,4,2,13,14,43,092,12,32,40,106,,03,25,303,14,08,24,197,14*70
$GPGSV,4,3,13,31,17,031,12,10,14,155,,11,05,224,,01,05,242,13*7F
$GPGSV,,1,4$M1600.91128,,506,6
LAT=1.377982 LON=103.855545 SAT=4 PREC=1626
CHARS=15718 SENTENCES=44 CSUM ERR=17
Hope this helps someone.
Rgds,
Gavin
