Pretty basic question - It's hard to find some answers due to all the layers involved in Galileo development.
I have a Grove LCD that on boot up displays an IP ADDR value on the screen. It seems to be generated from the linux boot versus any arduino related code. Could someone point me in the direction of the file that handles displaying this value? I know how to change it once the device is booted up, but I'd like to explore more of the start sequence code and understand that better. Thank you
Hi TeQ,
There are two standard (supported by Intel) ways of booting up a Galileo I know of:
a) Without SD
b) With SD
and none of them shows anything in a display by default... So please send your settings (al least those you know about):
a) OS (win, linux, version/distribution)
b) Arduino IDE version (or none?)
c) boot with SD?
d) A picture of your hardware (LCD connected to the Intel Galileo)
BR,
Fernando.
Hi -
So this is a kit that I have which came with a whole Spark arduino shield and some neat components.
a) It's running Linux quark014cf0 3.8.7-yocto-standard (Is there a newer version somewhere?)
b) Yea the Arduino IDE is latest, however this really doesn't seem to have anything to do with uploading sketches.
c) Yes it boots off SD
d) Pictures
So to be clear, when I reboot the whole device the IP ADDR displays by default on boot up. If I load a sketch that messes with the LCD screen, it overrides what's displayed. Rebooting the device again will reload the IP ADDR display code.
Hi again,
Maybe the Linux image you are using is not the one provided by Intel? You can find it at
https://software.intel.com/en-us/iot/hardware/galileo/downloads Downloads for the Intel® Galileo Board | Intel® Software
(https://software.intel.com/galileo-image/latest Latest Yocto* Poky Image (210 MB))
When I issue
uname -a
The Linux image I'm using shows the following output
Linux galileo 3.8.7-yocto-standard # 1 Thu May 12 08:17:14 PDT 2016 i586 GNU/Linux
what is the output in your case?
How did you get the image in the SD you are using? Where did you get the image file? If you've got the SD along with the kit I think it's possible you are using a Linux version "adapted" to your kit by the kit provider.
Just in case, please show the output of
ls -la /sketch
HTH,
Fernando.
Right so I did a uname -a previously and posted that "Linux quark014cf0 3.8.7-yocto-standard"
I did find a sketch.elf inside the /sketch folder but I'm pretty sure that was the last sketch I uploaded that controls servos. I removed all files from that directory and rebooted, the device still loads this IP ADDR on the lcd screen. I believe it must be something in the linux boot at this point?
Thanks for your help!
Then it is not the yocto provided by Intel. It does not mean it is erroneous, it's just another Linux yocto. Maybe if you find the answers to my previous questions:
you'll know about it.
Yes, I'm pretty sure it is something in the Linux (quark014cf0 3.8.7-yocto-standard) boot.
Do you need to know any detail about your LCD, IP address, etc.? Maybe we could move on anyhow... I would not be able to help on your original question
But I could try helping on getting the IP and using the Grove LCD with the standard Linux image provided by Intel.
You are welcome!
Fernando.
Hello TeQ,
Do you have any updates about this? Were Fernando's suggestions helpful? Please let us know if you still need assistance and we'll be more than glad to help you in any way we can.
Pedro M.
Hello, not yet - I am working on flashing the latest build of Linux for the device. My gut feeling is that this will also display the IP address on the LCD screen.
If anyone has a recommendation on where to look for any boot scripts and such on the linux OS for Galileo I think that would be very helpful.
I don't think so, but maybe I'm wrong, so your approach of "let's see what happens" seems to be the best one.
There are several threads/documents about boot scripts, I think the first one to read is
there are other comments/suggestions at
Even other examples
HTH,
Fernando.
I was able to flash the latest build onto a new SD card. Of course you get surprised with new issues with such big changes. The build I have Linux clanton 3.8.7-yocto-standard # 1 Fri Aug 22 10:42:53 PDT 2014 i586 GNU/Linux
There are some changes in the instructions in order to flash a SD card using DD on MacOS. Specifically relating the new options that were added to Disk Utility in newer versions of MacOS.
Newer problem is it seems the WiFi adapter is not working. I am able to login and run commands, however following instructions from this page https://software.intel.com/en-us/get-started-galileo-mac-step4 IoT - Step 4: Connect over Wi-Fi* | Intel® Software shows nothing when I run the command 'lspci -k | grep -A 3 -i "network"' and if I run connmanctl I receive: -sh: connmanctl: not found
I can report that the IP ADDR is currently not showing, but it seems the ethernet isn't initialized now so I'm not so sure!
wifi adapter and ethernet adapter do not depend on each other, they are completely independent at least at the initialization level.
I'm not able to help on the wifi side, but I can try to help with Ethernet.
Please boot the Intel Galileo with the Ethernet adapter plugged in (as it should) and send the utput of the command
ifconfig -a
Fernando.
I posted some information about using LCD screens with python and having it start automatically
see
hope this helps
rgb
PS
read through as some things changed over the time I was working on it
Hi rgb,
I think it's not related to the problem (which, btw, seems to be solved or discarded by the OP). Also, if the condition stated in your old post is still true
Wiring_x86 from Emutex Ltd works on the Edison, Galileo Gen 1 and Galileo Gen2 boards, but only with the standard Intel and AlexT's uClibc versions of Yocto for the Galileo, as hasn't been ported to the XDK IoT version
then it's not much useful either, since even when the uClibc based yocto linux seems to be maintained it's not the one suggested to use by Intel documentation.
Fernando.
Hi FGT
You may be right. I still use the uClibc based yocto linux in my classes, as nothing else worked as well when I was trying to figure out how to use the boards Intel donated, and it still does about everything I need it to do.
regards
rgb
rgb wrote:
Hi FGT
regards
rgb
I see. I use uClibc only when needed... which is a problem. Intel documentation seems to suggest (and maintain, I think) eglibc based yocto linux, even when they provide support to uClibc based yocto linux as well, to be honest.
I'd like to know your issues about eglibc based yocto linux, would you mind to post those in a thread? I'd keep using eglibc based yocto linux in my classes (I'm using donated Intel Galileo cards too) because I lose too much time (and I've seen too many students problems to understand...) explaining different Intel yocto images, versions, etc. and I like my students directly jump to handling some simple devices.
Fernando.
Hi FGT
The class I teach is a combination of Introduction to Engineering and Technical writing, and for the class I use the Galileo my goal is to give them an introduction to Linux and python programming and have them create projects that they write about, so don't have your problem with explaining anything about building images. For almost all, this is the first time they have toyed with Linux. The problem I had with the XDK IoT version was that it didn't have good support for python - couldn't run LCDs or servos easily. I toyed with teaching NodeJs, but figured it was too steep of a learning curve for students who had only previously worked with Arduino Uno boards. I still have not found a good NodeJS for dummies book, as opposed to the wealth of material on Python, and I was able to easily port Raspberry pi libraries, so have access to a wealth of material. I use the Flask web server(so have interactive web pages), i2c and SMBBus LCD screens, servos, motors and a lot of different sensors with no real problem. I can also cover changing the files that are read by the system and having processes start on bootup, so students get a pretty good introduction to the basics of Linux.
I also looked at many of the full versions of Linux, but at that time they were not finished and many became orphans.
As long as Alex keeps up the repository, I don't really plan to change. The repository is a bit limited, but thanks to pip and easy_install, I have pretty much anything I need. Pity Intel didn't set up a wikipedia, as has been suggested, so the lessons people have learned could be better shared. it also would be nice if there was something like the script that is running for the Raspberry pi repository that ports code over, so we had more choices, but what I have works for what I want to do, and both the students and the university are happy with my classes.
Hope this answered your question.
regards
rgb
