Community
cancel
Showing results for
Search instead for
Did you mean:
ABake3
Gstreamer MP3 plugin
Hey there.
I followed https://software.intel.com/en-us/articles/play-audio-from-your-intel-edison-via-bluetooth-using-adva... this document to get wav files to play using Gstreamer and pulseaudio over bluetooth to a speaker. At the end of the document it says:
"You may run into issues playing .mp3, stay tuned for updates."
Has anyone got mp3s to work? I'm currently using the wavparse plugin:
gst-launch-1.0 filesrc location= /home/root/music/sound.wav ! wavparse ! pulsesink
I would expect it to be mad for MP3:
gst-launch-1.0 filesrc location= /home/root/music/sound.mp3 ! mad ! pulsesink
But if I try that I get an error: "Your GStreamer installation is missing a plug-in."
I've got mp3s to play using mpg123 and alsa http://alextgalileo.altervista.org/blog/lets-make-noise-play-audio-edison/ from AlexT's repo and tutorials.
I'm wondering if anyone has the gstreamer plugins sorted
Sergio_A_Intel
Does this procedure work for .wav files? One alternative would be to convert the .mp3 files to .wav files.
You can try converting the .mp3 files to a .wav file and check if the command
gst-launch-1.0 filesrc location= /home/root/music/sound.wav ! wavparse ! pulsesink works for you.
Sergio
ABake3
Hi Sergio
Yes, I can play wav files with gstreamer, just not mp3 files.
I could convert the mp3 files to wav files as you suggest, it would allow me to keep going with my project, but in the long term I was intending to have a lot of music stored on the edison to play through a bluetooth speaker, so the MP3 compression would allow me to store more music.
I noticed AlexT has a load of gstreamer plugins in his repo http://repo.opkg.net/edison/repo/core2-32/ http://repo.opkg.net/edison/repo/core2-32/ but I haven't had chance to explore this yet.
Alex
Matthias_H_Intel
as far as I can see AlexT only has the gstreamer "good" plugins and not the "ugly" ones (http://gstreamer.freedesktop.org/data/doc/gstreamer/head/gst-plugins-ugly-plugins/html/ GStreamer Ugly Plugins 1.0 Plugins Reference Manual: GStreamer Ugly Plugins 1.0 Plugins Reference Manual) which would cover mp3.
Check gstreamer manual (http://gstreamer.freedesktop.org/data/doc/gstreamer/head/manual/manual.pdf http://gstreamer.freedesktop.org/data/doc/gstreamer/head/manual/manual.pdf) on the differences:
  • gstreamer: the core package
  • gst-plugins-base: an essential exemplary set of elements
  • gst-plugins-good: a set of good-quality plug-ins under LGPL
  • gst-plugins-ugly: a set of good-quality plug-ins that might pose distribution problems
  • gst-plugins-bad: a set of plug-ins that need more quality
  • gst-libav: a set of plug-ins that wrap libav for decoding and encoding
so you may check whether you can use a mp3 decoder out of the "ugly" plugins. Alternatively, there is also the Fluendo mp3 gstreamer decoder plugin you may want to check: http://core.fluendo.com/gstreamer/src/gst-fluendo-mp3/ Index of /gstreamer/src/gst-fluendo-mp3
AT9
Yeah, I've removed "ugly" ones exactly because of
which is not something I'm interested in dealing with
RAtlu1
New Contributor II
Hello Alex
I need the gst-plugins-ugly for h264 encoding. Any way of finding the opkg packages? Would be of great help
Thanking you
Matthias_H_Intel
you could build from sources directly on the target (just takes some time) if you don't have a Yocto build environment set up
AT9
Ditto to what @mhahn said. I'm not going to build packages for those, see my previous post.
