I've been out of the loop since about February and have decided to finally get back to a few projects that had been put on hold. One of the main sticking points with one project was the bugginess of the Edison's SPI interface. Have there been any improvements in terms of SPI or should I go work on other projects as nothing has been changed?
Hello Yodal,
I recommend you to flash the Edison with the latest Yocto image version. The SPI issues that you are referring to might have been fixed in this image: http://downloadmirror.intel.com/25028/eng/edison-image-ww25.5-15.zip http://downloadmirror.intel.com/25028/eng/edison-image-ww25.5-15.zip
Diego.
Hello Yodal,
Diego.
Is there any place I can see the change log for this version? I looked at the release notes that I found in the downloads section and only found changes for back in February.
Hello Yodal,
Have you checked this version of the release notes: http://download.intel.com/support/edison/sb/edison_rn_332032009.pdf http://download.intel.com/support/edison/sb/edison_rn_332032009.pdf? It is the most recent version of the release notes for the image 2.1 which is the latest one.
Diego.
