Community
cancel
Showing results for
Search instead for
Did you mean:
CLewi3
Have to use ifconfig usb0 down each time I restart edison
Anyone know a way to prevent having to call this command EVERY time I restart the edison? If I dont' call it I can't connect to it through XDK except over serial.
jhane2
I disable the usb0 interface by doing this in my build.
disable network on usb0
diff --git a/meta-intel-edison/meta-intel-edison-distro/recipes-core/systemd/systemd_%.bbappend b/meta-intel-edison/meta-intel-edison-distro/recipes-core/systemd/systemd_%.bb
index 07b6cb2..cc09b85 100644
--- a/meta-intel-edison/meta-intel-edison-distro/recipes-core/systemd/systemd_%.bbappend
+++ b/meta-intel-edison/meta-intel-edison-distro/recipes-core/systemd/systemd_%.bbappend
@@ -4,7 +4,6 @@ SRC_URI += "file://journald.conf \
file://system.conf \
file://systemd-reboot-service.patch \
file://hsu-pm-runtime.service \
- file://usb0.network \
file://edison-machine-id.service"
do_install_append() {
@@ -12,7 +11,6 @@ do_install_append() {
install -m 0644 ${WORKDIR}/journald.conf ${D}${sysconfdir}/systemd
install -m 0644 ${WORKDIR}/system.conf ${D}${sysconfdir}/systemd
install -m 0644 ${WORKDIR}/timesyncd.conf ${D}${sysconfdir}/systemd
- install -m 0644 ${WORKDIR}/usb0.network ${D}${sysconfdir}/systemd/network
# enable timesyncd service
install -d ${D}${sysconfdir}/systemd/system/sysinit.target.wants
fix ssh problem when usb0 net interface is disabled
- ssh was only being enabled when connected to a wired network(even though ssh over wifi worked) and when the usb0 network was disabled ssh stopped working. the nice comment in this file said this could be fixed by commenting out a line and now it works!
diff --git a/meta-intel-edison/meta-intel-edison-distro/recipes-connectivity/openssh/openssh/sshd.socket b/meta-intel-edison/meta-intel-edison-distro/recipes-connectivity/ope
index 2a1b012..b3749d2 100644
--- a/meta-intel-edison/meta-intel-edison-distro/recipes-connectivity/openssh/openssh/sshd.socket
+++ b/meta-intel-edison/meta-intel-edison-distro/recipes-connectivity/openssh/openssh/sshd.socket
@@ -6,7 +6,7 @@ ExecStartPre=/bin/mkdir -p /var/run/sshd
ListenStream=22
# restrict access to wired access for security reasons
# comment this line to remove restriction
-BindToDevice=usb0
+# BindToDevice=usb0
Accept=yes
[Install]
jeff
Pedro_M_Intel
Hello ChaseRLewis,
I personally have never faced this issue, I'm not sure what's the reason for it. Nevertheless I can give a way to work around it.
You will have to create a very simple shell script that includes the 'ifconfig usb0 down' command; it'll end up looking like this:
# !/bin/sh
ifconfig usb0 down
Let's say that you called the script downusb.sh and it is stored in /home/root/, then you will have to create a system service that disables the USB0 interface for you every time you turn the board on. It'll look like this:
# !/bin/sh
[Unit]
Description=Disables the usb0 interface automatically on boot
[Service]
ExecStart=/home/root/downusb.sh
Type=idle
[Install]
WantedBy=basic.target
We will call this service downusb.service and it has to be stored on /lib/systemd/system/. Once you have created it type the command 'systemctl enable downusb.service'.
Then you can reboot the system and it should disable it automatically.
Peter.
CLewi3
Is it normal to have to manually create all these directories? Also is it necessary to do something like vim? I created these directories but I don't see them after making them when looking inside the edison from my OS (windows). I tried to cd to them and none of them existed so I created them with mkdir but vim isn't by default on the edison and I can't navigate to them to them via the F: directory I can see when I connect to the Edison. ????
Pedro_M_Intel
No, it is not normal; all these directories should be on the Edison's file system. I mean you do have to create the files, but all the directories should already be there.
Are you connecting your Edison's internal Linux terminal? Or where exactly are you creating these directories?
If you are entering your Edison's terminal and you're not able to see those directories, then something might be wrong with your board's image. In that case I suggest you to re-flash the board.
Peter.
Carlos_M_Intel
Hi ChaseRLewis
Have you found a way to use the XDK without running the ifconfig usb0 down command?
Which image version do you have in your board? And, which XDK version are you using?
Charlie
