Intel® Makers
9881 Discussions
Hello, I am having this message in Eclipse: HAL/src/crt0.S: No such file or directory. (but that file actually DO exist in the directory, I found a folder and file) Anyone who knows how to fix this?
designerIntel
Aroop_B_Intel
Hi designerIntel,
What version of Eclipse are you using and have you made any changes to the installation?
Also, can you share the instructions that you are using to setup the Edison?
This may be related to your issue:
https://www.eclipse.org/forums/index.php/t/263075/
Aroop
