Intel® Makers
9880 Discussions
Help Temboo Intel Galileo Gen 2
JGarc41
Hello
I've tried to connect my Intel Galileo Gen 2 with Google Spreadsheets using Temboo
I set the Google account and the keys, but when I try to make it run it shows the next error:
I've been using this code
https://github.com/marcoschwartz/galileo-blueprints-book/blob/master/chapter6/Temboo/main.js https://github.com/marcoschwartz/galileo-blueprints-book/blob/master/chapter6/Temboo/main.js
I generated the codes using Temboo and it's correct, but it shows the next error when I run it
Carlos_M_Intel
Hi Reingher,
I was able to run the example on https://github.com/marcoschwartz/galileo-blueprints-book/blob/master/chapter6/Temboo/main.js galileo-blueprints-book/main.js at master · marcoschwartz/galileo-blueprints-book · GitHub
This is the configuration I am using:
XDK version: 2571
Open a Terminal Session and check the following commands, you should be getting those results too
uname -a
Linux galileo 3.8.7-yocto-standard # 1 Tue Sep 29 22:16:33 GMT 2015 i586 GNU/Linux
node --version
v0.10.38
npm --version
1.4.28
opkg list-installed xdk-daemon
xdk-daemon - 0.0.37-r0.0
I had to run on the Terminal the command npm install temboo in order to be able to run the code.
I did not make changes on the code and this is the output I'm getting. The TembooCredentialError is due to not have put any gmail credentials on the code.
Try with the configuration I'm using and let me know the outcome.
Charlie
Carlos_M_Intel
Hi Reingher,
XDK version: 2571
uname -a
node --version
v0.10.38
npm --version
1.4.28
Charlie
