Intel® Makers
9874 Discussions
Help with Sparkfun Intel Edison ADC Breakout board
kykaz
Hello folks, I am very new here and also new at the whole IOT and I was wondering if someone can help me with an issue with the SparkFun ADB Breakout board with an Intel Edison Mini Sparkfun breakout board and I am confused.
There is a lot of documentation about how to use a FlexSensor and the Edison using arduino, but I am using C++ and I found a few C++ sources in the sparkfun repo to read from analog to digital.
I also have a few touch sensors, compiling works well, no errors, but when I try to read from AN0, I get bogus data. I am including # include "SparkFunADS1015.h" and parkFunADS1015.cpp file into my project and like I said no compiling errors, I tried to use a 10k oHM and plug to ground(from connecting to ardino board documentation) but am using a sparkfun intel Edison min block], AN0 and 3.3 volts but does not seem to do anything, the ranges are .00002 to .000025.
When I used a touch sensor, I get no data.
What gives? Am I newbie enough not to understand this or is there something else missing (yes, am not an EE or a electrical voltage type of guy)
Any help would be appreciated
Products
https://www.sparkfun.com/products/13045 https://www.sparkfun.com/products/13045
https://www.sparkfun.com/products/13327 https://www.sparkfun.com/products/13327
https://www.sparkfun.com/products/8606 https://www.sparkfun.com/products/8606
https://www.sparkfun.com/products/8712 https://www.sparkfun.com/products/8712
https://www.sparkfun.com/products/13024 https://www.sparkfun.com/products/13024
Thanks again and I look forward for an answer
Carlos_M_Intel
Hi KarlosEdison,
I check the libraries you are using from: https://github.com/sparkfun/SparkFun_ADC_Block_for_Edison_CPP_Library GitHub - sparkfun/SparkFun_ADC_Block_for_Edison_CPP_Library: C++ library and example for using SparkFun's ADC block for …
These libraries use the MRAA library so I would like to know if you have the latest version on your board or which version do you have.
You can install the latest version by running the following commands:
echo "src iotkit http://iotdk.intel.com/repos/3.0/intelgalactic/opkg/i586 http://iotdk.intel.com/repos/3.0/intelgalactic/opkg/i586" > /etc/opkg/iotkit.conf
opkg update
opkg install mraa
I suggest you to also install the UPM library too (just in case), you can check some examples of this libray in:https://github.com/intel-iot-devkit/upm/tree/master/examples upm/examples at master · intel-iot-devkit/upm · GitHub. If you are using one of those sensors, the library will help you a lot.
opkg install upm
Also, check the raw readings from the ADC in /sys/bus/iio/devices/iio:device1, if you are using the AN0 you should be able to see the readings with cat /sys/bus/iio/devices/iio:device1/in_voltage0_raw. Start checking these files while using the sensors so you can see if the ADC is working or not, then you can start debugging the code and libraries.
Charlie
Carlos_M_Intel
Hi KarlosEdison,
opkg update
opkg install mraa
opkg install upm
Charlie
