Intel® Makers
9882 Discussions
Hi,I am getting an error "Error: Invalid AIO pin specified - do you have an ADC? ", while working with Intel EDISON board with Intel Iot XDK IDE,can any one help me in solving this issue?
TULASI_Y_Intel
Diego_V_Intel
Hi tulasi_yeditha,
Could you post the full code and tell me which Edison board you are using: Arduino Expansion Board or Mini-Breakout Board?
Diego
GGera4
Isn't the message that comes if you do not have access rights on the bus ?
I am not sure but it looks like what
Just guessing
TULASI_Y_Intel
Hi DiegoV_Intel,
I am using Edison Arduino Expansion board. This is the screen shot of code we are using, which is template given in XDK IDE for Analog Read.
Diego_V_Intel
Hi tulasi_yeditha,
Could you run the following command and let me know what the outcome is? I want to know what image version you are using: configure_edison --version
Diego
Carlos_M_Intel
Hi tulasi_yeditha
Have you been able to work on this? I would like to know if you have been able to run the code successfully.
Please let us know which image and XDK version you are using.
Charlie
