Intel® Makers
9880 Discussions
Hi, My edison have some problems.
JChoi20
HI,
Need some help getting my Arduino Edison working correctly and I'm a novice. When I power on edison and see boot process through terminal on MAC, a lot of 'FAILED ERROR"s came out.
PSH KERNEL VERSION: b0182929
WR: 20104000
SCU IPC: 0x800000d0 0xfffce92c
PSH miaHOB version: TNG.B0.VVBD.0000000c
microkernel built 10:14:01 Jan 13 2015
******* PSH loader *******
PCM page cache size = 192 KB
Cache Constraint = 0 Pages
Arming IPC driver ..
Adding page store pool ..
PagestoreAddr(IMR Start Address) = 0x04899000
pageStoreSize(IMR Size) = 0x00080000
*** Ready to receive application ***
U-Boot 2014.04 (Jan 30 2015 - 14:15:53)
Watchdog enabled
DRAM: 980.6 MiB
MMC: tangier_sdhci: 0
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
Target:blank
Partitioning already done...
Flashing already done...
GADGET DRIVER: usb_dnl_dfu
reading vmlinuz
5348960 bytes read in 132 ms (38.6 MiB/s)
Valid Boot Flag
Setup Size = 0x00003c00
Magic signature found
Using boot protocol version 2.0c
Linux kernel version 3.10.17-poky-edison+ (sys_dswci@tlsndgbuild004) # 1 SMP PREEMPT Fri Jan 30 14:16:35 CET 2015
Building boot_params at 0x00090000
Loading bzImage at address 00100000 (5333600 bytes)
Kernel command line: "root=PARTUUID=012b3303-34ac-284d-99b4-34e03a2335f4 rootfstype=ext4 console=ttyMFD2 earlyprintk=ttyMFD2,keep loglevel=4 systemd.unit=multi-user.target hardware_id=00 g_multi.iSerialNumber=cc877605fdf9da47745d608c86c4af8c"
Starting kernel ...
[ 1.698834] pmic_ccsm pmic_ccsm: Error reading battery profile from battid frmwrk
[ 1.706129] pmic_ccsm pmic_ccsm: Battery Over heat exception
[ 1.706219] pmic_ccsm pmic_ccsm: Battery0 temperature inside boundary
Welcome to Linux!
Expecting device dev-ttyMFD2.device...
Expecting device sys-subsystem-net-devices-wlan0.device...
[ OK ] Reached target Remote File Systems.
Expecting device dev-disk-by\x2dpartlabel-factory.device...
Expecting device sys-subsystem-net-devices-usb0.device...
[ OK ] Reached target Paths.
[ OK ] Set up automount Arbitrary Executable File Formats F...utomount Point.
[ OK ] Reached target Swap.
[ OK ] Created slice Root Slice.
[ OK ] Listening on Journal Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Listening on Delayed Shutdown Socket.
[ OK ] Created slice User and Session Slice.
[ OK ] Created slice System Slice.
Starting Create list of required static device nodes...rrent kernel...
Starting Apply Kernel Variables...
Starting udev Coldplug all Devices...
Starting Journal Service...
[ OK ] Started Journal Service.
Mounting Debug File System...
Starting Load Kernel Modules...
Mounting POSIX Message Queue File System...
[ OK ] Reached target Slices.
Starting Remount Root and Kernel File Systems...
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-getty.slice.
Mounting Temporary Directory...
[ OK ] Set up automount boot.automount.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Debug File System.
[ OK ] Mounted Temporary Directory.
[ OK ] Started Create list of required static device nodes ...current kernel.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started udev Coldplug all Devices.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
Mounting FUSE Control File System...
Mounting Configuration File System...
Starting Load/Save Random Seed...
Starting Create Static Device Nodes in /dev...
[ OK ] Mounted Configuration File System.
[ OK ] Mounted FUSE Control File System.
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
Mounting /var/volatile...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Mounted /var/volatile.
[ OK ] Reached target Local File Systems.
Starting Trigger Flushing of Journal to Persistent Storage...
Starting Create Volatile Files and Directories...
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Started Trigger Flushing of Journal to Persistent Storage.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Network Time Synchronization.
[ OK ] Found device /dev/disk/by-partlabel/factory.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Found device /dev/ttyMFD2.
Mounting Mount for factory...
[ OK ] Reached target System Initialization.
[ OK ] Reached target Timers.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Console System Startup Logging...
Starting Restore Sound Card State...
[ OK ] Mounted Mount for factory.
[FAILED] Failed to start Console System Startup Logging.
See 'systemctl status console-kit-log-system-start.service' for details.
[ OK ] Started Restore Sound Card State.
[ OK ] Found device /sys/subsystem/net/devices/wlan0.
[ OK ] Created slice system-systemd\x2drfkill.slice.
Starting Load/Save RF Kill Switch Status of rfkill2...
Starting Load/Save RF Kill Switch Status of rfkill1...
Starting Load/Save RF Kill Switch Status of rfkill0...
[ OK ] Reached target Sound Card.
[ OK ] Started Load/Save RF Kill Switch Status of rfkill2.
[ OK ] Started Load/Save RF Kill Switch Status of rfkill1.
[ OK ] Started Load/Save RF Kill Switch Status of rfkill0.
[ TIME ] Timed out waiting for device sys-subsystem-net-devices-usb0.device.
[DEPEND] Dependency failed for sshd.socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Watchdog sample daemon...</p...
Pedro_M_Intel
Hello chois,
There's something wrong with your Edison's image. There are a couple of methods we can try to recover your board to a stable state.
First, try using Flash Tool Lite, you will find the tool itself alongside a guide on how to use it in https://software.intel.com/en-us/iot/hardware/edison/downloads. https://software.intel.com/en-us/iot/hardware/edison/downloads.
If the method above doesn't work, then you should try the flashall method. You will find a guide on how to use it on Windows, Linux and OSX in .
Try these methods and let us know.
Peter.
Carlos_M_Intel
Hi chois,
Have you been able to use your board without problems?
Charlie
