Community
cancel
Showing results for
Search instead for
Did you mean:
JJair1
High frequency (300 MHz) digital switching
Jump to solution
Hello people!
I am currently working on a project that requires two pins switching from HIGH to LOW at around 300 MHz, when one is HIGH the other one is LOW. I wanted to know if the edison is capable of switching at those frequencies, and if so, can I code that program using the Arduino programming language, or do I need a more specialized programming language i.e. C?
Cheers!
Community Manager
That is impossible with the edison without external hardware...(maybe some dirty hacking can generate those frequency for example using the SD Card interface, for high GPIO speed see http://www.i-programmer.info/programming/hardware/8770-exploring-edison-fast-memory-mapped-io.html?s... Exploring Edison - Fast Memory Mapped I/O )
if you have one signal you can use a high speed inverter to get the other one (http://www.elm-tech.com/en/products/logic-ic-hs/elm7sh04xb/elm7sh04xb.pdf http://www.elm-tech.com/en/products/logic-ic-hs/elm7sh04xb/elm7sh04xb.pdf )
Flo1991
Community Manager
Flo1991
FIvan
