Intel® Makers
9868 Discussions
How can I control the onboard LED through sysfs?
en
Hi, I used the "Galileo IO Mappings" document to control pin 13, when I set this pin HIGH it doesn't light the onboard LED.
In the 'blink' sketch, setting pin 13 high does make the onboard LED light. But not with sysfs. What is the reason for this?
and how can I control the onboard LED with sysfs?
Erik_N_Intel
arduino_lover,
the onboard LED is not actually connected to pin 13. The board is set up so that when you call to pin 13 in an Arduino sketch, then this controls the onboard LED too (this was done so that the Blink sketch would work out of the box.)
If you want to control this LED through sysfs, then you need to write to gpio3. no muxes need to be set for this.
echo 3 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio3/direction
echo 1 > /sys/class/gpio/gpio3/value
Erik.
Erik_N_Intel
arduino_lover,
Erik.
RWald1
Innovator
arduino_4_life do you know where in the source code for the Arduino IDE (the version for Galileo) this alternate path is taken? I've been through all of the x86/cores/arduino code as I'm trying to figure out how a call to digitalWrite(13, HIGH|LOW) would be disambiguated.
