Community
cancel
Showing results for
Search instead for
Did you mean:
RWorn
How can I detect if HDMI monitor is on and resolution when connected to Intel Compute Stick?
Running an Intel Compute Stick (ICS) using Windows 10. Is there a way to programmatically detect if the HDMI monitor is turned on? Can I determine the connected resolution and change it (or force it) to 1080 if needed?
Community Manager
Hello rworner,
Thank you for reaching the Intel(R) Communities. I understand you would like to check if there is a way to confirm if the HDMI monitor is on or not. We can certainly get into that to find a possible answer.
Let me gather up some data to have a clearer understanding of the scenario faced.
  • Are you trying to set up a system for a remote control?
  • Is there a specific reason why you would like to get that done?
  • The resolution to be used depends on the monitor's capabilities
  • May I have the brand and model of the monitor used to check if that resolution can be done?
Thank you,
Esteban C
RWorn
We have been using the Intel Compute Sticks to push operational updates to monitors located in employee work locations. We are using Samsung DM65e commercial grade monitors/TVs.
In some cases the screens default to a 720 resolution instead of the typical 1080 resolution which skews the displayed content. So I am trying to see if there is a programmatic way to force the resolution to 1080.
Secondly I have another project using the same internal infrastructure where the customer wants to know if the monitors are turned on or off. I believe they are wanting to implement an energy saving feature and are looking to confirm that it is working.
MJenk1
I found https://www.reddit.com/r/sysadmin/comments/6gsz5j/set_windows_10_display_resolution_via_script/?st=j... this reddit thread which has a whole bunch of suggestions that might be helpful to you.
In Linux I used xrandr to achieve something similar.
In regards to your other project, what you might be looking for is HDMI-CEC, which is not currently supported.
Community Manager
rworner,
This is to do a follow up on your case and find out if you require further support about this matter.
Esteban C
