Intel® Makers
9881 Discussions
How can I execute a script on Edison memory using the Arduino IDE?
DLedo
I need to execute a script saved on Edison memory when an event comes on in my firmware.
I know the locate and name of it ( /folder/script.sh ) but I just don't know how to execute it using the arduino IDE.
Can someone help me with it?
Best regards.
Diego_V_Intel
Hello Ledo,
You can run Linux commands from the Arduino IDE using system calls. The syntax is the following: system("command");
So to execute a script you could use the following line in the Arduino sketch: system("sh /folder/script.sh");
Diego.
Diego_V_Intel
Hello Ledo,
Diego.
DLedo
Diego,
Thanks for your help.
It works with just a little change, just when I wrote system("/folder/script.sh"); without the first sh .
Ledo.
