Community
cancel
Showing results for
Search instead for
Did you mean:
JDono4
How can I make a nodejs script to auto run when Galileo starts up?
Jump to solution
Hi everybody,
I wrote a nodejs script for Galileo that launches a webserver and also reads the Grove temperature sensor. The script works pretty well. Now I want that script to run automatically when Galileo starts up.
The script is located at /home/root/ejemplos_node/temperature.js
To make the script to run when Galileo boots, I wrote the following bash script in the init.d folder (the script is called mystartup.sh):
# ! /bin/sh
node /home/root/ejemplos_node/temperatura.js
chmod +x /etc/init.d/mystartup.sh
./mystartup.sh
Then I executed the following commands on the console to change the permissions to make the bash script executable:
root@galileo:/etc/init.d# chmod +x /etc/init.d/mystartup.sh
root@galileo:/etc/init.d# chmod +x mystartup.sh
To check if the bash script is working, I executed:
root@galileo:/etc/init.d# ./mystartup.sh
and the script runs pretty well. That made me think that I had everything ready. However, if I reboot the Galileo, nothing happens. The script doesn't run and I don't know how to solve it.
Any help is welcome.
Juan
Tags (1)
Community Manager
Hi Juan,
Thanks for contacting us!
I appreciate all the information provided. I'd suggest you to create a system service in order to enable your script to run every time the Galileo boots. Please take a look at this thread for more details about how to create it: /message/461019# 461019 https://communities.intel.com/message/461019# 461019.
Hope you find this information useful.
-Yermi A.
Community Manager
Hi Juan,
-Yermi A.
JDono4
Hi Yermi,
Thank you so much. Now it is working!!!
Just a little comment: I created the system service in:
/etc/systemd/system
Juan
Community Manager
Hi Juan,
Thanks for confirming it works, I'm glad to help you.
Have a nice day!
-Yermi A.
