Community
cancel
Showing results for
Search instead for
Did you mean:
KMill10
Valued Contributor II
How can I stop clloader?
Hi everyone.
I'm working on using Edison as an embedded controller in a custom board for a corporate client of mine.
I do not need any Arduino compatibility or sketches - everything is done native in lInux.
I would like to kill off anything that's not needed, such as clloader but I think I am missing a step somewhere.
At the command prompt I do this (as root):
systemctl disable clloader.service
systemctl stop clloader.service
And sure enough the clloader process goes away, but it comes back at the next reboot.
Looks to me like some other process is starting it. Possibly launcher.sh?
Whats the correct way to just get rid of Arduino sketch compatibility completely?
MAski
See
KMill10
I saw that thread, but like I said above, that only lasts until a reboot and then clloader comes back.
I think something else is checking to see if clloader has been stopped, and restarting it.
Community Manager
Hello SpiderKenny,
Thanks for reaching out!
Have you tried removing the clloader package? In case you haven't I suggest you to do so, you can remove it with the command opkg remove clloader.
Let me know if that helps.
-Peter.
KMill10
Thanks Peter - that worked a treat.
Community Manager
Hi SpiderKenny,
I'm glad to be of help! If you have any other doubts, please don't hesitate to contact us back.
-Peter.
IIstv
Hi SpiderKenny,
systemctl disable sketch_reset.service
systemctl stop sketch_reset.service
Istvan
