Community
cancel
Showing results for
Search instead for
Did you mean:
JKim94
How can I use floating point unit(FPU) in edison when using Arduino IDE
Jump to solution
My project requires fast floating point calculations. (such as trigonometric functions)
I want to use Intel Edison for this project, and I prefer Arduino IDE as programming Interface.
But I wonder if I can use Edison's FPU when I use arduino IDE.
Is FPU automatically used when I program edison on arduino IDE?
If not, how can I use it?
Diego_V_Intel
Hello electroid,
You can use the float data type to perform calculations using float point numbers. I'm not sure if that is what you wanted to know. I recommend you to check the following article written by SparkFun. There are test results for different calculations and different data types using an Arduino UNO: https://learn.sparkfun.com/tutorials/data-types-in-arduino Data Types in Arduino
If you check that article, you will see a test result for a divide operation with float point numbers. According to that test, it took 32us to be done. I did the same test with Edison and it took 4us, which is 8 times faster.
I hope this information helps you.
Diego.
Diego_V_Intel
Hello electroid,
Diego.
