Intel® Makers
9872 Discussions
How can i make serial comunication using pin rx/tx intel galileo to arduino uno, in my plan i set intel galileo as receiver as arduino uno as sender?
RPras
I try use this code in arduino as sender:
int t=2;
void setup(){
Serial.begin(9600);
void loop(){
Serial.write(t);
I use this code in intel galileo :
int incomingByte;
void setup() {
Serial.begin(9600);
void loop() {
if (Serial.available() > 0) {
incomingByte = Serial.read();
Serial.print("I received: ");
Serial.println(incomingByte);
After i upload, i see in the serial monitor (intel galileo),, there is nothing...
please your help, thankyou
FTinetti
Honored Contributor I
int t=2;
void setup(){
Serial.begin(9600);
void loop(){
Serial.write(t);
int incomingByte;
void setup() {
Serial.begin(9600);
void loop() {
hmmm... I do not understand your idea... I think this would not work in an "Arduino-only" setup either (i.e. trying to use 2 Arduinos), would you please show the connection (cabling) with your current Intel Galileo <==> Arduino setup?
Fernando.
RPras
Yes,, actually that is in arduino-arduino,, but i try it in galileo-arduino, the cabling i just connect tx galileo to rx arduino, and tx arduino to rx galileo...
I try in arduino-arduino that's can,, i think galileo have equation with arduino. thats why i try galileo-arduino. but can't
FTinetti
Well... this is even more strange...
at least, I've never seen this usage, and it would mean you are using the Serial interface for both: communicating with another Arduino and with your PC via USB Please send a picture and/or video showing how it works, it's interesting as a debugging environment, actually.
About the Arduino-Intel Galileo connection: Intel Galileo Serial does not use Rx-Tx, but another Linux device. In order to use Intel Galileo RX-Tx, you should use Serial1 in your sketch. Yes, Intel Galileo Serial is not Intel Galileo Rx-Tx.
HTH,
Fernando,
Community Manager
Hello Radikia_Cuber,
I was wondering if you had the chance to check the questions kindly asked by FGT.
If you have any other question or update, don't hesitate to contact us.
Andres V.
RPras
Actually i use that way because dht can't work in galileo,,
Dht work in arduino then i try use arduino to read dht then the data tmprature n humidity from arduino (use dht) send to galileo....
How can i use rx tx in galileo?
FTinetti
See my previous post, more specifically:
HTH,
Fernando.
RPras
Thankyou for the reply,
But,
What is Serial 1?
FTinetti
But,
What is Serial 1?
Serial1, used as Serial, but it uses the Rx-Tx hardware. Modifying a little bit your code for the Galileo:
int incomingByte;
void setup()
Serial.begin(); // For showing something in the Arduino IDE Serial Monitor
Serial1.begin(9600); // For receiving data from Arduino
void loop()
if (Serial1.available() > 0) // Is there any thing sent from Arduino?
incomingByte = Serial1.read(); // Read data sent from Arduino
Serial.print("I received: "); // Show data in the Serial Monitor
(take a look where Serial1 is used)
HTH,
Fernando.
Community Manager
I was wondering if you had the chance to check the suggestion provided by FGT.
Andres V.
