Intel® Makers
9880 Discussions
How could Edison run Arduino program without link with computer.
Community Manager
I have upload my Arduino program to Edison, it runs well link with computer.
But I don't know, how to programming the Edison that make it runs without computer.
Thanks!
Community Manager
Hello Danny_I,
I'm not sure I understand what happening but let me try to understand the issue and help you.
Does your Arduino sketch works when your board is connected to your PC and stops when you disconnect it?
Or, is your Arduino sketch not persistent?
Or are you simply looking for a way of programming your Edison without a PC?
-Peter.
Community Manager
Hello Peter,
Thank you for your reply.
My board stop working when it disconnect to my PC.
I tried programming in Arduino IDE, but none of the programmer choice in the menu list works for Edison.
-Danny
Community Manager
Which image are you currently using? Have you already tried to flash the latest image? (Which can be downloaded from https://software.intel.com/en-us/iot/hardware/edison/downloads.
Please try flashing it and let us know if the issue persists. By the way, there's a known issue where Arduino sketches are not persistent in images newer than version 146. Nevertheless, a user has found a workaround for this issue, you can find it in: https://communities.intel.com/message/319509# 319509 https://communities.intel.com/message/319509.
-Peter.
Community Manager
Thank you,I will try it.
Community Manager
Thank you for letting us know, we'll be waiting for your reply.
-Peter.
Community Manager
Hello Danny,
Do you have any update about this? Do you still need help?
-Peter.
