How could I disable this function/popup? It's just appeared and then the local wifi is disconnected from internal network.
Hello, JJ_Auto. Thank you very much for sharing your issue with the Intel Communities Team. I will be more than glad to assist you.
In this case, for you to disable this pop-up, please follow these steps:
- Go to the system tray icons and look for the Intel® Remote Keyboard app or simply type it on the Windows* search bar and double-click it.
- Click on the "Options tab".
- Click on "Disable Hosted Network".
Antony S.
Antony S.
Hello, JJ_Auto.
I would like to double check if you were able to perform the troubleshooting steps that I attached to the post above and the results.
Antony S.
After I close this popup as you advised then I also turn off the another access point that make this popup show when on.
It seems work fine but i'm not sure if I turn on the access point.
Thank you.
