Hi
when I try to load any arduino code ,this is the error I get : " i586-poky-linux-g++: error: C:\Users\GEEKUL~1\AppData\Local\Temp\build2224798869796166844.tmp/core.a: No such file or directory
Error compiling." ,and I have no idea how to fix it please help.
Thanks in Advance.
Hi Dineo,
I haven't seen that error, but it seems to be caused by the Arduino IDE itself. When using the Edison module, I prefer using the Arduino IDE 1.6.0 because you don't have to install any additional package and the IDE doesn't require to be installed in the PC to be used. I recommend you to uninstall your current Arduino IDE and then, download the 1.6.0 version from the following link: http://downloadmirror.intel.com/24783/eng/IntelArduino-1.6.0-Windows.7z http://downloadmirror.intel.com/24783/eng/IntelArduino-1.6.0-Windows.7z.
Try again to upload an Arduino sketch and see if you get the same error. If so, please take a screenshot of the error message.
Diego
Hi Dineo,
Diego
Hi Diego
thank you for the helpful guideline ,its working fine now.
Dineo
