Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
How do I setup a serial connection with intel edison
Jump to solution
Before it was required to setup the wifi, but now there's no guide.
TKirv1
New Contributor II
Assuming you have flashed yocto, this tells you how to do it. Just click on the instructions for your computers operating system.
https://software.intel.com/en-us/setting-up-serial-terminal-intel-edison-board IoT - Setting up a serial terminal | Intel® Software
-Thomas
TKirv1
New Contributor II
-Thomas
Community Manager
ok, so Im following the guide, but every time I try opening the connection I get a blank screen and nothing happens when I press enter twice.
note:
I set the com port to intel edison virtual com port (which is com13) and I set the speed to 115200 baud.
TKirv1
New Contributor II
The guide says to use the USB serial port not the virtual com port. Did you try that?
Community Manager
I was actually using a faulty cable or one of the cables was the wrong voltage, because I used the intel edison virtual com port because the serial port wasn't showing. anyway, now Im using a micro usb to usb cable which was provided with the PS4 and now it's running smoothly.
