Intel® Makers
9881 Discussions
How do I transfer files between my pc and the edison?
Community Manager
I am following the steps from this document, but I'm struggling with steps 3 and 4. for step 3 I copied the files from the iotkit-comm-c-master folder from github but for step 4 I'm not sure how I would copy a file from the edison to a the path on my laptop. How do I go about copying files between the edison and my pc?
Community Manager
Hi PandaBanda,
You can use an SD card to transfer the file from the Edison to the PC. Another option is to setup SSH in your Edison and use a software called WinSCP to access the Edison from your PC using SSH and then copy the file directly to your PC.
Diego
Community Manager
Hi PandaBanda,
Diego
