Intel® Makers
9880 Discussions
How do i run two sketches at the same time?
ARami7
so here's my first sketch:
# include
Servo myservo; // create servo object to control a servo
void setup() {
myservo.attach(11);// put your setup code here, to run once:
myservo.write(150); // tell servo to go to position in variable 'pos'
delay(2500); // waits 15ms for the servo to reach the position
myservo.write(120); // tell servo to go to position in variable 'pos'
void loop() {
// put your main code here, to run repeatedly:
notice the 2.5 second delay? i want to run THIS while 2.5 seconds are elapsing, and not AFTER 2.5 seconds:
# include
void setup() {
myservo.attach(10);// put your setup code here, to run once:
myservo.write(165 ); // tell servo to go to position in variable 'pos'
delay(200); // waits 15ms for the servo to reach the position
void loop() {
maybe the solution is not running two sketches at the same time, but what code can launch even though there is a delay
** through SSH i run the sketch files individually with this command:
/media/servo1/sketch.elf ./sketch.elf /dev/ttyGS0
when i use this code through putty in ssh, my sketch file runs, so i wanted to launch two at the same time or re-work my code to run simultaneously even though there is a 2.5 second delay
FTinetti
Honored Contributor I
Maybe I'm losing something, but if you have 2 servos and you have to move each one 2 times with specific delays (I copy your code here and delete comments because I find them confusing):
myservo.attach(11);
myservo.write(150);
delay(2500);
myservo.write(120);
and
myservo.attach(10);
myservo.write(165);
delay(200);
myservo.write(120);
then
myservo1.attach(11);
myservo2.attach(10);
myservo1.write(150);
myservo2.write(165);
delay(200);
myservo2.write(120);
delay(2300);
myservo1.write(120);
HTH,
Fernando.
FTinetti
myservo.attach(11);
myservo.write(150);
delay(2500);
myservo.write(120);
and
myservo.attach(10);
myservo.write(165);
delay(200);
myservo.write(120);
then
delay(200);
delay(2300);
HTH,
Fernando.
Pedro_M_Intel
Hello AdanChristo,
Running more than one sketch at the time is not advisable since, let's say you are running two sketches and they both are running at the same time, in that case, they could be competing for the same hardware resources.
So, I'd suggest you to try something similar to what Fernando suggested. Or something similar to:
# include
Servo myservo;
void setup() {
myservo.attach(11);
myservo.write(150);
myservo.attach(10); //Run this and time it
myservo.write(165 ); //then change the delay
delay(200); //bellow to 2.5s minus
myservo.write(120); //the time this takes
delay(X);
myservo.write(120);
void loop() {}
Peter.
