Intel® Makers
Intel® Edison, Intel® Joule™, Intel® Curie™, Intel® Galileo
Welcome - This is a Peer-to-Peer Forum only. Intel has discontinued these products but you may find support from other customers on this Forum
9868 Discussions
How do you use the JTAG port on Galileo?
RHart
This is not an XDP port. So how do you make use of the JTAG port?
Thanks!
ADRIAN_B_Intel
Thats correct, its not the typical XDP port, its just a 10 connector and you can buy this adapter for example
https://www.olimex.com/Products/ARM/JTAG/ARM-JTAG-20-10/ https://www.olimex.com/Products/ARM/JTAG/ARM-JTAG-20-10/
then one of these FTDI type debuggers can be used to get on chip debug of Galileo. (and other supported by OpenOCD may work fine)
http://www.tincantools.com/wiki/Flyswatter2 http://www.tincantools.com/wiki/Flyswatter2
https://www.olimex.com/Products/ARM/JTAG/ARM-USB-OCD/ https://www.olimex.com/Products/ARM/JTAG/ARM-USB-OCD/
OpenOCD/GDB is being used as the debugger software and that will be available for download in the coming months.
I will update this thread as soon as its available.
thanks..
ADRIAN_B_Intel
thanks..
ADRIAN_B_Intel
How to source level debug the linux kernel using openocd:
/docs/DOC-22203 https://communities.intel.com/docs/DOC-22203
Thomas_F_Intel
The source patch for OpenOCD is available now.
We are currently working with the OpenOCD maintainers to get the patch accepted to the public trunk. But until it's accepted, you can download the patch here: http://openocd.zylin.com/# /c/1829/ http://openocd.zylin.com/# /c/1829/
SPipe2
Hello !
Maybe it is not the right place to post, but I appreciate any help ...
I built the openocd program from the git repo ,configured with --enable-ftdi option. I want to use it with the ARM-USB-OCD-H jtag adapter (bought from olymex)
https://www.olimex.com/Products/ARM/JTAG/ARM-USB-OCD-H/ https://www.olimex.com/Products/ARM/JTAG/ARM-USB-OCD-H/
When I run the program i have the following issue :
sanyi@desktop:~/openocd-code$ openocd -f /usr/local/share/openocd/scripts/interface/olimex-arm-usb-ocd-h.cfg -f /usr/local/share/openocd/scripts/board/quark_x10xx_board.cfg
Open On-Chip Debugger 0.8.0 (2014-09-02-21:20)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.sourceforge.net/doc/doxygen/bugs.html http://openocd.sourceforge.net/doc/doxygen/bugs.html
Error: The specified debug interface was not found (ft2232)
The following debug interfaces are available:
1: ftdi
2: usb_blaster
3: usbprog
4: jlink
5: vsllink
6: rlink
7: ulink
8: arm-jtag-ew
9: hla
10: osbdm
11: opendous
12: aice
Runtime Error: /usr/local/share/openocd/scripts/interface/olimex-arm-usb-ocd-h.cfg:7:
in procedure 'script'
at file "embedded:startup.tcl", line 58
in procedure 'interface' called at file "/usr/local/share/openocd/scripts/interface/olimex-arm-usb-ocd-h.cfg", line 7
I am running on Debian Wheezy (7.6.0 64 bit).
lsusb shows me :
Bus 005 Device 009: ID 15ba:002b Olimex Ltd.
Thank you.
SPipe2
I found the problem:
Openocd v0.8.0 use the config file from /usr/local/share/openocd/scripts/interface/ftdi/ not from /usr/local/share/openocd/scripts/interface/ :
sanyi@desktop:~/openocd-code$ openocd -f /usr/local/share/openocd/scripts/interface/ftdi/olimex-arm-usb-ocd-h.cfg -f /usr/local/share/openocd/scripts/board/quark_x10xx_board.cfg
Info : only one transport option; autoselect 'jtag'
adapter speed: 4000 kHz
trst_only separate trst_push_pull
Info : clock speed 4000 kHz
Info : JTAG tap: quark_x10xx.cltap tap/device found: 0x0e681013 (mfg: 0x009, part: 0xe681, ver: 0x0)
enabling core tap
Info : JTAG tap: quark_x10xx.cpu enabled
