Intel® Makers
9881 Discussions
How does one interface the Intel Galileo with Processing?
CO3
I have been tasked with working with the Galileo Gen 2 board for a group assignment involving the completion of an augmented reality sandbox. While researching online, I have not had much luck with a source that exclusively states how an Intel board could connect with Processing, an open-source software sketchbook. This kind of technology is something I have not worked with in the past. Would anyone happen to know a few sources that could assist in connecting a Galileo to a projector with the use of Processing for this kind of project?
--Thank you in advance,
Cristol
Carlos_M_Intel
Hi Cristol,
As you may know the suported IDEs are Eclipse, Arduino and the XDK so you should contact them (https://forum.processing.org/two/ All Categories - Processing 2.x and 3.x Forum) for more information about how to use the Galileo through Processing.
I haven't found information about the Galileo and Processing but I found a link withhttps://software.intel.com/en-us/blogs/2015/07/13/motion-sensing-with-intel-edison an example for the Edison + Processing. I hope you will find it helpful.
Charlie
Carlos_M_Intel
Hi Cristol,
Charlie
