Community
cancel
Showing results for
Search instead for
Did you mean:
ARami7
How does one turn on LED from the network?
Jump to solution
pc connected to gen 2 through a patch cable, and from the PC sending commands to turn on LED, how does one do this? any links?
Diego_V_Intel
Hi AdanChristo,
I recommend you to check the WebServer example in the Arduino IDE. It is under File>Examples>Ethernet>WebServer. You can also look for similar projects in the web; there are several projects and examples for Arduino. You could check them and adapt the examples to be used with Galileo. Anyhow, the WebServer example is a good point to start, I recommend you to check it.
Diego
FTinetti
Honored Contributor I
Maybe you should follow your other thread first, since it seems that you cannot get the blink example to work.
Fernando.
Diego_V_Intel
Hi AdanChristo,
Diego
