Intel® Makers
9867 Discussions
How to Set Timezones on Linux Yocto? Intel Galileo
RMorti
Hi
I'm using AlexT's repo and tried to set the timezone of my intel galileo board, but can't figure out how to do it.
i tried with tzdata, but its not installed (get tzdata command not found) and can't install the packet with opkg
i don't have the files at /etc/localtime neither the directory /usr/share/zoneinfo/, or i don't know where
i tried with ntpdata and is running, but the timezone is wrong, so it mess up my time everytime i set it manually. I tried setting different servers, but every server gives me the same time, even the ones that should have the same timezone as me.
i'm trying to set the zone at South America - Buenos Aires.
Thanks in advance and sorry for my english
Eliza_D_Intel
Hello RMorti, Thank you for your interest in the Intel Galileo Board. Please use the below guide to set the date and time on Yocto environment - https://www.oreilly.com/openbook/debian/book/ch07_05.html?fbclid=IwAR0pchQFZrQASfvba83JdeKTWiVflCQoS... Thank you and best regards, Eliza
RMorti
Thanks for the answer, i tried the steps on your link, but i can't use the command tzcongif, same problem with tzdata i get "-sh: tzconfig: command not found"
also i tried every step here:
http://freelinuxtutorials.com/quick-tips-and-tricks/quick-tip-change-timezone-in-linux-in-different-...
none works, mostly because i'm getting the "command not found"
Eliza_D_Intel
Hello RMorti, In this case, please do the following: Use the command: timedatectl list-timezones This will list all the times zones available in the system. Please remember your time zone from here. After you have located your time zone, please use the command: timedatectl set-timezone ZONE, where ZONE is the time zone you have seen previously. Thank you, Eliza
RMorti
same problem, i get "-sh: timedatectl: command not found"
Eliza_D_Intel
Hello RMorti, What is the Linux image that you are using? I have tested it with Galileo_Poky_SW_image_20160606.zip from: https://downloadcenter.intel.com/download/26418/Intel-Galileo-Board-Support-Package Thank you, Eliza
RMorti
i'm using AlexT's image
http://repo.opkg.net/galileo/images/
i think its a moded version of the default image from the intel site with dev tools
Eliza_D_Intel
Hello RMorti, Unfortunately, I am not familiar with the commands that can be used with this SD Image. In order to use the commands I have mentioned before, please use the Galileo_Poky_SW_image. Best regards, Eliza
RMorti
Hi, AlexT's version is a Poky version with dev tools (checked the version with command lines).
sadly i couldn't contact Alex with this new forum to ask him directly if he could help me.
By the way, i could solve my problem (kinda), i needed the right time zone, because i'm collecting sensors data in a MySQL database in this data its included the date and time, using Current_date() and Current_time() fuctions from MySQL.
i solve my problem by subtracting the hour on the mysql query like this: current_time() -30000 (minus 3 hours).
i said kind, because i will have problems at midnight, when the date changues the day.
i struggled a lot to install and make it work both mysql and apache2 on Alex's image, you know if its possible to install and use both of these packets on the image you linked? if it allows some packet manager like opkg, apt, etc?
because the default image i tried from the intel support site, didn't worked for me.
Eliza_D_Intel
Hello RMorti, The image I have used is the official SD Image for Intel Galileo. Best regards, Eliza
RMorti
OK, I think It gonna be kinda hard to build my own image from ground since I have working mostly of the functions I need on this image I'm gonna keep testing to find a solution Obtener Outlook para Android<https://aka.ms/ghei36>
FerryT
Valued Contributor I
Using @Alex_Intel​ 's repo you should be able to build the packages your are missing (`bitbake tzdata`). You should then be able to copy them to you device and install using the package manager.
Or, you can build your own repo, add it to your package manager (I use dpkg and deb's so I'm not familar with opkg). Then when you install a package it will resolve dependencies automatically. For edison, this is how I do it: https://edison-fw.github.io/meta-intel-edison/5.0-Creating-a-deb-repository.html
With this 2nd method you can easily add all packages that are not included by Alex, without rebuilding everything.
