Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
How to achieve the communication between the MCU and the Host?
Dear friends,
I want to send some datas from the MCU to the Host cpu,
According to the document, https://software.intel.com/en-us/node/557355 https://software.intel.com/en-us/node/557355
I found the APIs:host_send() and host_receive(),so i download the program
which contains the host_send() API.But what should i do to receive the datas
sent by the MCU? Is there any API in MRAA i could use or someother ways?
Thank you!
Highlighted
isn't it just coming in via /dev/tty??? serial?
Highlighted
Hello hexuyangguang,
I believe mhahn is right, you should be able to receive the data sent by the MCU on /dev/ttymcu0.
Peter.
Highlighted
Hello,mhahn,
Thank you for the replay,I learned that Every host_send call from the MCU will trigger an interrupt to host CPU.
Is it a serial interrupt ? Could you explain something in details?
I am not familar with this part!
Thank you!
@Intel_Peter
Highlighted
Hello,Peter,
I want to send data from the MCU to the Host CPU in high speed,and I saw there is a way called Shared Memory in the below:
Could it be achieved in this way? if so,How?Is the any document refer to ?
Thank you!
Highlighted
As you can see in https://software.intel.com/en-us/node/557354# Communicating_between_the_host_and_the_MCU Using the MCU SDK and API: Code examples | Intel® Developer Zone, the MCU communicates with the CPU by running the script found under the 'Communicating between the host and the MCU' section. And in fact a few lines bellow the script you can find the instructions on how to read the data sent by the MCU.
Regarding shared memory, a thread on how it works can be found in .
Peter.
