Intel® Makers
9881 Discussions
How to add mraa/gpio library to the arduino
YWang92
Hi all,
I'm using Intel Edison and trying to run a GPIO example. First I include signal.h and mraa/gpio.h, but the error message appeared when I compiled the codes.
Arduino: 1.6.5 (Windows 8.1), Board: "Intel® Edison"
sketch_nov13b.ino:3:23: fatal error: mraa/gpio.h: No such file or directory
compilation terminated.
Error compiling.
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Does anyone know how to solve this problem? Thank you!
Yicheng
Pedro_M_Intel
Hello wych,
I'm afraid that's not the right way to use MRAA. I'll give you a brief explanation on how to use MRAA with your Edison, for this you will have to access your board's Linux terminal, here's a guide on how to do it: https://software.intel.com/en-us/get-started-edison-windows-step3 IoT - Step 3: Set up a serial terminal | Intel® Developer Zone.
1. Set up AlexT's repo. Learn how to do it in http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html Edison Package Repo Configuration Instructions.
2. Run the commands "opkg update" and "opkg install libmraa0".
3. Now, to run the simple blink code:
# include
# include
# include
# include "mraa/gpio.h"
int main(int argc, char** argv)
mraa_platform_t platform = mraa_get_platform_type();
mraa_gpio_context gpio, gpio_in = NULL;
char* board_name = mraa_get_platform_name();
int ledstate = 0;
gpio = mraa_gpio_init(13);
fprintf(stdout, "Welcome to libmraa\n Version: %s\n Running on %s\n", mraa_get_version(), board_name);
mraa_gpio_dir(gpio, MRAA_GPIO_OUT);
for (;;) {
if (gpio_in != NULL && mraa_gpio_read(gpio_in) == 0) {
return 0;
ledstate = !ledstate;
mraa_gpio_write(gpio, !ledstate);
sleep(1);
return 0;
Create a file with the code called blink.c and save it, then run the command "gcc blink.c -o blink.out -lmraa", this will create an executable file called blink.out, run it with "./blink.out" and you should see a blinking LED on your board.
Peter.
Pedro_M_Intel
Hello wych,
# include
# include
# include
int ledstate = 0;
for (;;) {
return 0;
sleep(1);
return 0;
Peter.
YWang92
Thank you Peter! I am sorry to say I am only a beginner in Linux, could you tell me more detail steps about how to replace anything I have in /etc/opkg/base-feeds.conf? Like what command should I use to get to the file /etc/opkg/base-feeds.conf and how to replace things as the instruction shows?
===/etc/opkg/base-feeds.conf contents below===
src/gz all http://repo.opkg.net/edison/repo/all http://repo.opkg.net/edison/repo/all
src/gz edison http://repo.opkg.net/edison/repo/edison http://repo.opkg.net/edison/repo/edison
src/gz core2-32 http://repo.opkg.net/edison/repo/core2-32 http://repo.opkg.net/edison/repo/core2-32
===end of /etc/opkg/base-feeds.conf contents===
Thank you again!
Yicheng
Pedro_M_Intel
Sure wych, follow these steps:
echo "src/gz all http://repo.opkg.net/edison/repo/all http://repo.opkg.net/edison/repo/all" > /etc/opkg/base-feeds.con
echo "src/gz edison http://repo.opkg.net/edison/repo/edison http://repo.opkg.net/edison/repo/edison" >> /etc/opkg/base-feeds.con
echo "src/gz core2-32 http://repo.opkg.net/edison/repo/core2-32 http://repo.opkg.net/edison/repo/core2-32" >> /etc/opkg/base-feeds.con
opkg update
That should set up the AlexT's repo and download the mraa library.
Peter.
