Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
How to add the NFS support for the target image and the ext3 filesystem?
Hi everyone,
I'm trying to add the NFS support for the Galileo. Is there any How-To to describe the task since I'm a new developer for the Galileo platform? Here are what I have done:
1. Get the new config file for linux image through "bitbake linux-yocto-quark -c menuonfig"
2. Enable the NFS support config options by adding an extra nfs-extra.cfg file under:
meta-iot-devkit/recipes-kernel/linux/linux-yocto-quark/iot-devkit. and include the config file in linux-yocto-quark_3.8.bbappend
Here are the contents for the file:
CONFIG_NFS_FS=y
CONFIG_NFS_V2=y
CONFIG_NFS_V3=y
3. Bitbake image-full. After booting the new image, I've checked the system through "cat /proc/filesystems". And the NFS was supported by the new kernel.
4. mount a remote network file system by doing "mount -t nfs ...". But this command failed. It prompts some helper should be provided.
It seems I have to add some extra binutils support for the mount?
James Jiao.
Juan_M_Intel
Hi BG4BMH,
Which Quark BSP did you use to build the image? Also, could you attach a screenshot of the error? Finally, if you build an uclibc image, have you tried installing util-linux-mount from AlexT http://alextgalileo.altervista.org/package-repo-configuration-instructions.html repo? In case you haven't, you can install it with the following command:
opkg install http://repo.opkg.net/galileo/repo/i586/util-linux-mount_2.22.2-r3_i586.ipk http://repo.opkg.net/galileo/repo/i586/util-linux-mount_2.22.2-r3_i586.ipk
Remember to set up the internet connection before running the command.
JPMontero_Intel
Community Manager
Hi JPMontero_Intel,
Here is the console output:
////first make sure the nfs was supported by the kernel:
root@quark:/bin# cat /proc/filesystems
nodev sysfs
nodev rootfs
nodev bdev
nodev proc
nodev cgroup
nodev cpuset
nodev tmpfs
nodev devtmpfs
nodev debugfs
nodev sockfs
nodev pipefs
nodev anon_inodefs
nodev rpc_pipefs
nodev devpts
ext3
ext2
nodev ramfs
nodev hugetlbfs
vfat
nodev nfs
nodev autofs
fuseblk
nodev fuse
nodev fusectl
nodev mqueue
nodev efivarfs
/////second, mount the remote nfs filesystem:
root@quark:/bin# mount -t nfs 192.168.0.105:/srv/quarkimage /mnt -o rw,nosuid
mount: wrong fs type, bad option, bad superblock on 192.168.0.105:/srv/quarkimage,
missing codepage or helper program, or other error
(for several filesystems (e.g. nfs, cifs) you might
need a /sbin/mount. helper program)
In some cases useful info is found in syslog - try
dmesg | tail or so.
root@quark:/bin#
I used the
DISTRO ?= "iot-devkit-multilibc"
to compile the full image.
Is there anything I've missed?
James Jiao
Juan_M_Intel
Hi BG4BMH,
Thanks for the additional information, the only thing missing is the BSP version, are you using BSP 1.1.0 or BSP 1.2.0?
JPMontero_Intel
Community Manager
I use the 1.1.0 bsp.
James Jiao
Juan_M_Intel
Hi BG4BMH,
Make sure you added all NFS dependencies in the menuconfig. Additionally I'd try installing nfs-export-root and nfs-utils from the https://github.com/openembedded/openembedded-core openembedded-core layer. Then build the image with both packages.
JPMontero_Intel
