Intel® Makers
9874 Discussions
How to auto run c (Eclipse mraa) at bootup of Edsion
LLee28
Recently I've been trying to program using Mraa library. I started by building a blink LED project and succeeded. But after i reboot Edison, the LED didn't respond. So the program didn't run at bootup.
I know I should do some linux thing on edison, but I know little on Linux. Pls help.
Lane
Community Manager
Hi Lane_Lee,
That happens because the script uploaded using Eclipse is stored in the /temp directory, which is cleaned every time the board boots. I recommend you to check the following threads, you will find a discussion about this same topic and a solution to run the C/C++ scripts automatically on startup:Regards,
Diego
Community Manager
Hi Lane_Lee,
Diego
LLee28
Dear Diego,
Thanks for your info and guidance.
Lane
