Community
cancel
Showing results for
Search instead for
Did you mean:
JDunn
How to burn my ISO to ICS
Jump to solution
Dear all
I want to burn my customized OS to ICS, could you share how to burn my image to ICS. thanks in advance
Best regards
Jasper.
VPevo
Write it to an SD card and boot from the SD card to install on the internal memory.
VPevo
JDunn
Hi VyReN,
Thanks , got it, let me try that
PFern5
I tried burn ins a USB drive, but could't make the Stick boot from it
Any ideas ?
I see only a black screen
VPevo
Try the USB drive in a different PC, I'll bet it does the same thing. If so, something isn't right with the bootable USB.
Cesar_B_Intel
Hello PauloCesar1301
Please confirm your image on the USB is a boot-able one as VyReN recommended.
You could get more information here https://technet.microsoft.com/en-us/library/jj200124.aspx https://technet.microsoft.com/en-us/library/jj200124.aspx *
Caesar B _Intel .
*Other names and brands may be claimed as the property of others.
