I have a VOC sensor(mics-vz-89f). It can i2c communication at STD mode(100kbit)
but Edison i2c mode is Fast mode(400kbit)
How to changing edison i2c mode? fast -> std
I try to rebuild kernel, but I got errors.
Please, Help me
Loading cache: 100% |# | ETA: 00:00:00
Loaded 2238 entries from dependency cache.
WARNING: No recipes available for:
/home/kyu/Downloads/iot-devkit-yp-poky-edison-20160606/build_edison/../poky/meta-intel-iot-devkit/recipes-kernel/linux/linux-yocto-quark_3.8.bbappend
NOTE: Resolving any missing task queue dependencies
NOTE: multiple providers are available for jpeg (jpeg, libjpeg-turbo)
NOTE: consider defining a PREFERRED_PROVIDER entry to match jpeg
NOTE: multiple providers are available for runtime java2-runtime (cacao, jamvm, openjdk-8-jre, openjdk-7-jre, openjdk-6-jre)
NOTE: consider defining a PREFERRED_PROVIDER entry to match java2-runtime
NOTE: multiple providers are available for virtual/java-native (cacao-native, jamvm-native)
NOTE: consider defining a PREFERRED_PROVIDER entry to match virtual/java-native
NOTE: multiple providers are available for jpeg-native (jpeg-native, libjpeg-turbo-native)
NOTE: consider defining a PREFERRED_PROVIDER entry to match jpeg-native
NOTE: multiple providers are available for runtime java2-vm (openjdk-7-jre, openjdk-6-jre)
NOTE: consider defining a PREFERRED_PROVIDER entry to match java2-vm
NOTE: multiple providers are available for virtual/java-initial-native (cacao-initial-native, jamvm-initial-native)
NOTE: consider defining a PREFERRED_PROVIDER entry to match virtual/java-initial-native
Build Configuration:
BB_VERSION = "1.24.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "Ubuntu-14.04"
TARGET_SYS = "i586-poky-linux"
MACHINE = "edison"
DISTRO = "poky-edison"
DISTRO_VERSION = "1.7.3"
TUNE_FEATURES = "m32 core2"
TARGET_FPU = ""
meta
meta-intel-arduino
meta-intel-edison-bsp
meta-intel-edison-distro
meta-intel-iot-middleware
meta-java
meta-oic
meta-filesystems
meta-networking
meta-oe
meta-python
meta-ruby
meta-webserver
meta-yocto
meta-yocto-bsp = ":"
NOTE: Preparing runqueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
WARNING: Failed to fetch URL http://serf.googlecode.com/svn/src_releases/serf-1.3.7.tar.bz2, attempting MIRRORS if available
WARNING: Failed to fetch URL http://www.apache.org/dist/subversion/subversion-1.8.9.tar.bz2, attempting MIRRORS if available
WARNING: Checksum failure encountered with download of http://icedtea.classpath.org/hg/release/icedtea7-forest-2.1/archive/f89009ada191.tar.bz2;name=openjd... - will attempt other sources if available
WARNING: Renaming /home/kyu/Downloads/iot-devkit-yp-poky-edison-20160606/build_edison/downloads/f89009ada191.tar.bz2 to /home/kyu/Downloads/iot-devkit-yp-poky-edison-20160606/build_edison/downloads/f89009ada191.tar.bz2_bad-checksum_2bc941373ca4b033c9a25f972eec7858
ERROR: Fetcher failure for URL: ' http://icedtea.classpath.org/hg/release/icedtea7-forest-2.1/archive/f89009ada191.tar.bz2;name=openjd...'. Checksum mismatch!
File: '/home/kyu/Downloads/iot-devkit-yp-poky-edison-20160606/build_edison/downloads/f89009ada191.tar.bz2' has md5 checksum 2bc941373ca4b033c9a25f972eec7858 when c26bbb33addfaeb14d28a1329b4b5a3e was expected
File: '/home/kyu/Downloads/iot-devkit-yp-poky-edison-20160606/build_edison/downloads/f89009ada191.tar.bz2' has sha256 checksum 5efd8e66f18fcbf45527bcc74aa3e6ed11f66bc793c88e3841925c4acb4827ba when 54a0ef02b56b265b4122324e08a33c42ececbf2a300ada260611e7b6ccdba96d was expected
If this change is expected (e.g. you have upgraded to a new version without updating the checksums) then you can use these lines within the recipe:
SRC_URI[openjdk.md5sum] = "2bc941373ca4b033c9a25f972eec7858"
SRC_URI[openjdk.sha256sum] = "5efd8e66f18fcbf45527bcc74aa3e6ed11f66bc793c88e3841925c4acb4827ba"
Otherwise you should retry the download and/or check with upstream to determine if the file has become corrupted or otherwise unexpectedly modified.
ERROR: Function failed: Fetcher failure for URL: ' http://icedtea.classpath.org/hg/release/icedtea7-forest-2.1/archive/f89009ada191.tar.bz2;name=openjd...'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/kyu/Downloads/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/x86_64-linux/icedtea7-native/2.1.3-r1.0/temp/log.do_fetch.2908
ERROR: Task 3003 (/home/kyu/Downloads/iot-devkit-yp-poky-edison-20160606/build_edison/../poky/meta-java/recipes-core/icedtea/icedtea7-native_2.1.3.bb, do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2106 tasks of which 2087 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There were 5 WARNING messages shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
Hello dev_kor,
Thanks for reaching out!
If you'd like to build the standard image, you should follow these steps:
Make sure you are using Ubuntu 16.04 (I tested this steps on kernel version 4.4.0-38-generic) and have the following versions of Git, tar, and Python:
Git 1.7.8 or greater
tar 1.24 or greater
Python 2.7.3 or greater excluding Python 3.x, which is not supported.
Install all the dependencies with the command:
sudo apt-get install gawk wget git-core diffstat unzip texinfo gcc-multilib \
build-essential chrpath socat libsdl1.2-dev xterm
Download and unzip iot-devkit-yp-poky-edison-20160606.zip ( http://iotdk.intel.com/src/3.5/edison/iot-devkit-yp-poky-edison-20160606.zip).
Go to iot-devkit-yp-poky-edison-20160606/poky/meta-intel-edison/meta-intel-edison-distro/recipes-core/images/edison-image.bb and comment or delete the following lines:
IMAGE_INSTALL += "iotkit-comm-js"
IMAGE_INSTALL += "iotkit-comm-c-dev"
Go to http://git.yoctoproject.org/cgit/cgit.cgi/meta-java/commit/recipes-core/icedtea/openjdk-7-03b147/sig...
Download the patch and unzip it.
Go to iot-devkit-yp-poky-edison-20160606/poky/meta-java/recipes-core/ant and delete the file called ant-native_1.8.1.bb, replace it with the file with the same name found in /meta-java-master/recipes-core/ant/.
Go to iot-devkit-yp-poky-edison-20160606/poky/meta-java/recipes-core/icedtea/ and delete the file called icedtea7-native_2.1.3.bb, replace it with the file with the same name found in /meta-java-master/recipes-core/icedtea/.
Go to iot-devkit-yp-poky-edison-20160606/poky/meta-java/recipes-core/icedtea/openjdk-7-03b147/ and delete the file fix-checksums.patch, replace it with the file with the same name found in /meta-java-master/recipes-core/icedtea/openjdk-7-03b147/.
Go to iot-devkit-yp-poky-edison-20160606/poky/meta-intel-iot-devkit/recipes-connectivity/bacnet-stack and open the file called bacnet-stack_0.8.2.bb. Look for the line:
SRC_URI = " http://sourceforge.net/projects/bacnet/files/bacnet-stack/bacnet-stack-${PV}/bacnet-stack-${PV}.tgz \
And change it for:
SRC_URI = " https://svwh.dl.sourceforge.net/project/bacnet/bacnet-stack/bacnet-stack-0.8.2/bacnet-stack-0.8.2.tg... \
Then follow the usual steps:
cd iot-devkit-yp-poky-edison-20160606/poky/
source oe-init-build-env ../build_edison/
bitbake edison-image u-boot
../poky/meta-intel-edison/utils/flash/postBuild.sh .
zip -r toFlash.zip toFlash
These steps were tested successfully by me and other two users in https://communities.intel.com/thread/111630 https://communities.intel.com/thread/111630. Once the modifications mentioned above are completed the building process shouldn't throw you any errors, then you can continue with your own modifications. Try it and let us know how it goes.
I hope this information helps you,
Pedro M.
I believe with the latest builds, kernel option CONFIG_I2C_DW_SPEED_MODE_DEBUG is already enabled
Check out this post for details...
I agree with joe_nasti, however, I would like to know if you were able to build the image with the steps I provided you above.
Pedro M.
