Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
How to compile C++ on Yocto Linux using terminal
Excuse me if this has been asked and answered. I'm a student at UMass Lowell in Electrical & Computer Engineering. Our Microprocessors Professor is having us use the Gen 2 Intel Galileo, and we cannot seem to find how to compile C++.
Our project requires that we communicate to the Galileo using the serial USB cable and a terminal, such as PuTTY. In our last assignment, we read ADC values (from an external chip) and displayed them on terminal of the computer screen of a laptop connected via the serial USB cable. We used "cc" to compile our code. (As far as I know, gcc is not available in this distribution of this operating system.)
For our next project, we are supposed to use Open CV (Computer Vision) to write C++ code to control the provided webcam. The webcam installed at video0 under /dev/ correctly, but we still cannot figure out how to use any C++ compiler. How can we compile C++ on the Intel Galileo using the provided distribution of Yocto Linux using the serial USB cable?
G
FYI, using g++ instead of cxx just locks the OS and does nothing. Using cc does not compile c++.
FTinetti
Honored Contributor I
Hi Taric25,
I think the Linux development environment on the board is stable since some time ago. Take a look at the post by Paul.Guermonprez with a lot of material at (including C and C++ code)
Just in case, I've tested gcc and g++ n my board and it looks like it's running fine:
root@galileo:~# gcc
gcc: fatal error: no input files
compilation terminated.
root@galileo:~# g++
g++: fatal error: no input files
root@galileo:~# gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/gcc/i586-poky-linux/4.9.1/lto-wrapper
Target: i586-poky-linux
Configured with: /export/users/neck/iotdk_3.5_dev/workdir/build_galileo/tmp/work-shared/gcc-4.9.1-r0/gcc-4.9.1/configure --build=x86_64-linux --host=i586-poky-linux --target=i586-poky-linux --prefix=/usr --exec_prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --libexecdir=/usr/lib/gcc --datadir=/usr/share --sysconfdir=/etc --sharedstatedir=/com --localstatedir=/var --libdir=/usr/lib --includedir=/usr/include --oldincludedir=/usr/include --infodir=/usr/share/info --mandir=/usr/share/man --disable-silent-rules --disable-dependency-tracking --with-libtool-sysroot=/export/users/neck/iotdk_3.5_dev/workdir/build_galileo/tmp/sysroots/quark --with-gnu-ld --enable-shared --enable-languages=c,c++ --enable-threads=posix --enable-multilib --enable-c99 --enable-long-long --enable-symvers=gnu --enable-libstdcxx-pch --program-prefix=i586-poky-linux- --without-local-prefix --enable-target-optspace --enable-lto --enable-libssp --disable-bootstrap --disable-libmudflap --with-system-zlib --with-linker-hash-style=gnu --enable-linker-build-id --with-ppl=no --with-cloog=no --enable-checking=release --enable-cheaders=c_global --with-sysroot=/ --with-build-sysroot=/export/users/neck/iotdk_3.5_dev/workdir/build_galileo/tmp/sysroots/quark --with-native-system-header-dir=/export/users/neck/iotdk_3.5_dev/workdir/build_galileo/tmp/sysroots/quark/usr/include --with-gxx-include-dir=/usr/include/c++/4.9.1 --enable-targets=all --enable-nls --enable-__cxa_atexit
Thread model: posix
gcc version 4.9.1 (GCC)
root@galileo:~# g++ -v
COLLECT_GCC=g++
Thread model: posix
What version of yocto are you using?
root@galileo:~# cat /etc/version
201606081532
Fernando.
Community Manager
Hi, FGT,
Here is what I get when I copy the .direct image file inside the "Latest Yocto* Poky Image" from https://software.intel.com/en-us/iot/hardware/galileo/downloads https://software.intel.com/en-us/iot/hardware/galileo/downloads to the SD card.
I would tell you what version I was using last night, except one of my teammates modified the SD card since I last used it, so I am not able to get that information. Our Teaching Assistant (TA) loaded something on our SD card from his personal github, and now g++ works. I wish I could give you what version we were using last, because it would help other people who have this problem. Whatever it's worth, here is the version I am using now.
I'm sorry for wasting your time.
FTinetti
Hi Taric25,
Never mind, it's good to know your Intel Galileo is now "Up & Running".
Actually, the version showing the output
201606081532
(which you have now) is the one you should use.
BR,
Fernando.
