Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
How to configure Button in quark D2000 kit?
Jump to solution
Hi
I Have this cod example but in the new software version 1.1. doesn't work, I have This error: Too few arguments to function 'qm_gpio_read_pin'
I see in the documentation that now its needs more arguments : int qm_gpio_read_pin ( const qm_gpio_t gpio, const uint8_t pin, qm_gpio_state_t const state )
I'm having trouble in figure this out, can same one help me on this.
Thanks for the help
MFF
* D2000_Button
* Read the state of the on board user defined switch and print
* the result to a serial terminal
** This software is offered strictly as is with no **
** warranties whatsoever. Use it at your own risk. **
# include
/* User defined switch is Digital IO 5 [F2] */
# define BUTTON 2
/* GPIO configuration structure (see qm_gpio.h for details) */
static qm_gpio_port_config_t DDRcfg;
bool state,laststate; /* these will hold the states of the pin */
int main(void)
/* send message to terminal */
QM_PRINTF("D2000_Button is running \n\n");
/* set GPIO to input by resetting the associated bit in the DDR*/
DDRcfg.direction=0<<2;
qm_gpio_set_config(QM_GPIO_0,&DDRcfg);
laststate=qm_gpio_read_pin(QM_GPIO_0,BUTTON);
/* get the initial state of the button */
if(laststate)
QM_PRINTF("Button is not pressed \n");
else
QM_PRINTF("Button is pressed \n");
while(1) /* loop forever */
if (state!=laststate)
laststate=state;
if(laststate)
else
return 0; /* never gets here */
Michelle_C_Intel
Hi ,
The additional argument needed is the GPIO Pin 'State'.. qm_gpio_state_t
* GPIO pin states.
typedef enum {
QM_GPIO_LOW = 0, /**< GPIO low state. */
QM_GPIO_HIGH, /**< GPIO high state. */
QM_GPIO_STATE_NUM /**< Number of GPIO states. */
} qm_gpio_state_t;
Below is an example of how to use it -- I think this should accomplish what you were aiming to do in your code ...
# include
# include
# define BUTTON 2
int main(void)
qm_gpio_state_t state;
qm_gpio_port_config_t cfg;
/*Set GPIO Mode*/
qm_pmux_select(QM_PIN_ID_2,QM_PMUX_FN_0);
/* set GPIO to input */
qm_pmux_pullup_en(QM_PIN_ID_2, true);
qm_pmux_input_en(QM_PIN_ID_2, true);
cfg.direction=BIT(0);
qm_gpio_set_config(QM_GPIO_0,&cfg);
while(1)
qm_gpio_read_pin(QM_GPIO_0,BUTTON, &state);
if (state == 1)
QM_PRINTF("Button is pressed %d\n" , state);
else
QM_PRINTF("Button is not pressed %d\n" , state) ;
return 0;
--Michelle.
Michelle_C_Intel
Hi ,
* GPIO pin states.
typedef enum {
} qm_gpio_state_t;
# include
# include
# define BUTTON 2
int main(void)
/*Set GPIO Mode*/
while(1)
if (state == 1)
else
return 0;
--Michelle.
Community Manager
What changes should I make to have the led light up when I press the button.
Thanks for the help
MFF
Michelle_C_Intel
Hi ,
You could define an output GPIO pin (PIN_OUT) and then just replace the QM_PRINTF's with qm_gpio_set_pin/qm_gpio_clear_pin
qm_gpio_set_pin(QM_GPIO_0, PIN_OUT);
qm_gpio_clear_pin(QM_GPIO_0, PIN_OUT);
However that will only light the LED while the button is pressed... If you want to toggle the LED on/off based on a button press then you need to configure an interrupt on the button... example below should work with QMSI 1.1.
/* QMSI GPIO app example
* PIN_OUT will be configured as an output pin and PIN_INTR will be
* configured as an input pin with interrupts
* enabled.
* On the Intel(R) Quark(TM) Microcontroller D2000 Development Platform PIN_OUT
* and PIN_INTR are marked "SSO 10" and "A0".
# include "qm_gpio.h"
# include "qm_interrupt.h"
# include "qm_isr.h"
# include "qm_pinmux.h"
/* Connect LED to PIN_OUT */
# define PIN_OUT 0
/*Connect Button to PIN_INTR */
# define PIN_INTR 3
/* Example callback function */
static void gpio_example_callback(void *, uint32_t);
int main(void)
/* Request IRQ and write GPIO port config */
cfg.direction = BIT(PIN_OUT);
cfg.int_en = BIT(PIN_INTR); /* Interrupt enabled */
cfg.int_type = BIT(PIN_INTR); /* Edge sensitive interrupt */
cfg.int_polarity = BIT(PIN_INTR); /* Rising edge */
cfg.int_debounce = BIT(PIN_INTR); /* Debounce enabled */
cfg.int_bothedge = 0x0; /* Both edge disabled */
cfg.callback = gpio_example_callback;
qm_irq_request(QM_IRQ_GPIO_0, qm_gpio_isr_0);
qm_gpio_set_config(QM_GPIO_0, &cfg);
/* Set PIN_OUT to trigger PIN_INTR interrupt*/
while(1)
/* Your code goes here */
return 0;
void gpio_example_callback(void *data, uint32_t status)
/* toggle LED state - ON/OFF */
qm_gpio_read_pin(QM_GPIO_0,PIN_OUT,&state);
if(state == 0)
else{
