I am trying to send serial information from a Texas Instruments Launch Pad (Arduino Compatible) to a Gen 1 Intel Galileo which is running Linux and Node.js with a SerialPort.js module included to read the received UART data. The transmit pin on the Launch Pad is connected to the Rx (Pin 0) of the Galileo. The Galileo is to act as a web server and the data to be sent is simply 3 bytes of data with a terminating "\n" at the end of each transmission to tell the server that it is the end of the data.
Here are two functions that I wrote for the Launch Pad that places the information in to the transmit buffer to be sent. Testing the output of the UART on the launch pad shows that the information is coming out correctly.
void uartCHAR(int txChar)
while (!(IFG2 & UCA0TXIFG)); //Wait for the transmit buffer to be ready
UCA0TXBUF = (char)txChar; //Put integer value in to UART transmit buffer in character format
void uartTransmit(int tx)
P1OUT |= REDLED; //Turn on Red LED
unsigned int byteSelect = 0xFF00; //Declare value used to isolate each byte
unsigned int byteHold = 0; //Declare varible to hold isolated byte
unsigned char sendByte = 0; //Declare a variable to hold the byte to be transmitted
int k; //Declare a variable to be used in the for loop
for (k = 1; k>=0 ; k--) //Cycle through the code twice
byteHold = byteSelect&tx; //Isoltate each section of 8 bits in the and store in byteHold
byteHold >>= (8*(k)); //Shift the data down to the lowest byte position
sendByte = byteHold;
uartCHAR(sendByte); //Pass sendByte in to the uartCHAR function
byteHold = 0;
byteSelect>>=8; //Shift the byte selector to the next section of 8 bits
P1OUT &= ~REDLED; //Turn off Red LED
uartCHAR('\n'); //Send symbol to indicate to the parser that the end of the message has arrived
Here is a bash script that I found to configure the UART before running the JavaScript code to turn on the server functions.
# !/bin/bash
# Initialize sysfs to use the uart on pins 0 and 1 as /dev/ttyS0:
echo -n "4" > /sys/class/gpio/export
echo -n "40" > /sys/class/gpio/export
echo -n "41" > /sys/class/gpio/export
echo -n "out" > /sys/class/gpio/gpio4/direction
echo -n "out" > /sys/class/gpio/gpio40/direction
echo -n "out" > /sys/class/gpio/gpio41/direction
echo -n "strong" > /sys/class/gpio/gpio40/drive
echo -n "strong" > /sys/class/gpio/gpio41/drive
echo -n "1" > /sys/class/gpio/gpio4/value
echo -n "0" > /sys/class/gpio/gpio40/value
echo -n "0" > /sys/class/gpio/gpio41/value
stty -F /dev/ttyS0 raw
stty -F /dev/ttyS0 9600
Here is the section of the JavaScript code using Node.js and SerialPort.js to listen for data on the UART.
var express = require('express');
var app = express();
var io = require('socket.io').listen(app.listen(4000));
var com = require("serialport");
app.get('/', function(request, response){response.sendfile(__dirname + "/home.html");});
app.use('/static', express.static(__dirname + '/public'));
var activeClients = 0;
io.sockets.on('connection', function(socket){clientConnect(socket);});
var serialPort = new com.SerialPort("/dev/ttyS0", {
baudRate: 9600,
dataBits: 8,
parity: 'none',
stopBits: 1,
flowControl: false,
parser: com.parsers.readline("\n")
serialPort.on('open',function() {
console.log('Port open ');
console.log(process.argv[0] + " " + " " + process.argv[1]);
serialPort.on('data', function(data) {
console.log("Data recieved: ");
console.log(data.toString());
io.sockets.emit('heartUpdate', {heartcrc:data});
emitHeartRate(data);
serialPort.on('close', function () {
console.log('Port close');
serialPort.on('error', function (...
Hello Skywatermelon,
Why don't you try using mraa? You can get it on the eglibc image by modifying the file /etc/opkg/iotdk.conf to contain the following lines:
src iotdk-all http://iotdk.intel.com/repos/2.0/iotdk/all http://iotdk.intel.com/repos/2.0/iotdk/all
src iotdk-i586 http://iotdk.intel.com/repos/2.0/iotdk/i586 http://iotdk.intel.com/repos/2.0/iotdk/i586
src iotdk-quark http://iotdk.intel.com/repos/2.0/iotdk/quark http://iotdk.intel.com/repos/2.0/iotdk/quark
src iotdk-x86 http://iotdk.intel.com/repos/2.0/iotdk/x86 http://iotdk.intel.com/repos/2.0/iotdk/x86
And then entering the commands:
opkg update
opkg install mraa
Once you've done that you will be able to use mraa in your code. You can check the following link to find a working serial example that you might be able to implement on your code:
https://github.com/MakersTeam/Galileo/blob/master/Serial_test.js https://github.com/MakersTeam/Galileo/blob/master/Serial_test.js
Let me know if it helps.
Peter.
opkg update
opkg install mraa
Peter.
