Hello. I have an Intel Edsion.
# uname -a
Linux edison 3.10.98-poky-edison+ # 1 SMP PREEMPT Mon Jun 6 14:32:08 PDT 2016 i686 GNU/Linux
When I plug in an USB device I get such output:
# dmesg |grep -i usb
[67600.164342] usb 1-1: new full-speed USB device number 96 using dwc3-host
[67600.164473] usb 1-1: Device not responding to set address.
[67600.374373] usb 1-1: Device not responding to set address.
[67600.584261] usb 1-1: device not accepting address 96, error -71
lsusb also doesn't output my USB device.
# lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Here I read that "I need to install usb to serials driver for this issue. By doing so I was able to get it working.".
How can I install usb to serial driver?
Hello nikfisher,
It would depend on the device you are using. I mean, if you are not using the same device mentioned in the thread you posted, your process might be different.
The first step you should take is to look for the device's driver for Linux and check if it is compatible with Edison's kernel, which as you mentioned is 3.10.98 in the current image.
Once you found whether the image is compatible with Edison's kernel or not, you have to check how it can be installed. If it can be simply installed on the OS or if you need to build the image in order to include the driver. As I mentioned, this will vary depending on your device.
If you would like to know how build your custom image and include packages such as drivers, I suggest you to read and understand the following documents:
http://www.intel.com/support/edison/sb/CS-035278.htm
http://www.yoctoproject.org/docs/1.7.2/mega-manual/mega-manual.html
I hope this information helps you.
-Peter.
Hello nikfisher,
-Peter.
