Intel® Makers
9868 Discussions
How to configure the Intel Edison as an udp server in an adhock network ?
JJoac3
I have done some experiments with the edison (systemstudio, C ++ , Win7).
The integration into an existing network via wifi was also ok.
But the next Steps are not clear: I would like to use the edison with a special hardware for measurements.
The edison should be an udp Server that responds to requests from a (Android-)Client. But there is no AP / Network, it must be an adhoc Connection.
Now is the question how is to configure the System?
What is to do with the system settings and what in application? Normally is assumed that the edison is integrated into a network (SSID, key, PW)
Which IP is to be used?
An example would be helpful.
Thanks and greetings
Achim
Community Manager
Hello Achim,
Thank you for interest in the Intel® Edison Breakout Board.
I understand that you want to measure a variable with a special hardware, then transfer the data to your Edison board, which acting as a UDP server, should send information, when requested, to an Android client. All of this through an ad-hoc connection.
I have a question before presenting what I've found so far, are you not able to use an AP network or you don't want to use one? Because if you can, you should check this link https://communities.intel.com/message/442354# 442354 https://communities.intel.com/message/442354# 442354 in order set the Edison as an UDP server.
Generally, the UDP communication part is more Linux related than Edison related, so here is a link that may help you program UDP sockets http://www.binarytides.com/programming-udp-sockets-c-linux/.
Regarding the ad-hoc connection, the Intel Edison Wi-Fi Guide, section 4.2.4 ( http://www.intel.com/content/dam/support/us/en/documents/edison/sb/edison_wifi_331438001.pdf), gives the necessary steps to create/connect to such network.
In case you need further assistance, don't hesitate to contact us.
Andres V.
JJoac3
Hi Andres,
thanks for your mail.
....UDP ad-hoc Connection: At the moment is to be used an android tablet (as terminal).
Some tablets can not open a WiFi hotspot if they don't have internet-accsess. The final user does not allow the use of tabets with internet option.
If the case the EDISON is configured as an AP, I assume that the energy consumption is higher!?
This path would be not optimal also for other reasons (using of multiple devices....)
I tried to program the edison (wifi Guide, 4.2.4 create / connect to an ad-hoc network).
There were 2 Problems:
1. I don't found the directory with the file 'edison_env' to load the wpacli_ibss_open.sh - script.
my edison directory is empty !?
C:\>dir F:\
Datenträger in Laufwerk F: ist EDISON
Volumeseriennummer: 80C7-D7A4
Verzeichnis von F:\ <--- empty
Datei nicht gefunden
C:\>
2. Because I have configured one edison (as adhoc nw), but it haven't not worked completely.
These are the Settings:
mailto:root@edison_gfxxxx root@edison_gfxxxx:~# ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:48644 errors:0 dropped:0 overruns:0 frame:0
TX packets:48644 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:3696976 (3.5 MiB) TX bytes:3696976 (3.5 MiB)
usb0 Link encap:Ethernet HWaddr 02:00:86:77:6a:b0
inet addr:192.168.2.15 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fe80::86ff:fe77:6ab0/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:5296 errors:0 dropped:0 overruns:0 frame:0
TX packets:3730 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:3045212 (2.9 MiB) TX bytes:531807 (519.3 KiB)
wlan0 Link encap:Ethernet HWaddr 78:4b:87:ad:31:95
inet addr:192.168.0.10 Bcast:192.168.0.255 Mask:255.255.255.0
RX packets:553 errors:0 dropped:0 overruns:0 frame:0
TX packets:1187 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:29532 (28.8 KiB) TX bytes:343779 (335.7 KiB)
mailto:root@edison_gfxxxx root@edison_gfxxxx:~# wpa_cli status
Selected interface 'wlan0'
bssid=00:24:d7:6a:03:09 --> PC
ssid=edison_gfxxxx (ad-hoc network: why that ?)
id=0
mode=IBSS
pairwise_cipher=CCMP (*)
group_cipher=CCMP (*)
key_mgmt=WPA2-PSK (*)
wpa_state=COMPLETED
ip_address=192.168.0.10 --> Edison
p2p_device_address=7a:4b:87:ad:31:95
address=78:4b:87:ad:31:95
With this setting works the data exchange, but the PC must be AP. (in this case)
(*) i can't cange this positions
It would be great if i could adjust directly the edison network parameters (for one device, s.a. unix scripts )
I would be glad about help.
Greetings Achim
JJoac3
Hi Andres,
For better understanding, I would like to show my goal.
I hope the edison isn't the wrong way.
Greetings Achim
Community Manager
Hello Achim,
You mentioned that the data exchange is working, but the PC is not configured as an AP yet. What is preventing your PC from being used as an AP? What are you currently using as an AP?
In the link previously provided (https://communities.intel.com/message/442354# 442354 https://communities.intel.com/message/442354# 442354), it is mentioned that the Edison should be put in AP mode, even if you are using it as an UDP transmitter/receiver.
Is the access point in Step 3 different from the PC in steps 1 and 2?
I'll be waiting for your response.
Andres
JJoac3
Hi Andres,
AP: We must use android tablets with no internet-accsess. That means, that a lot of these devices can't open a hotspot and thus therefore can not be an access point.
Yesterday we corrected our concept. The edison will be the master and AP, the tablet client.
The originally planned ad hoc network is becoming more and more difficult. Normally Android does not support an ad hoc Network, and so is it necessary to make changes.
But the licensing conditions become more stringent.
Now i have set the edison as an AP, the connection to the Android device worked fine.
The real device will be a router - this will be connected via a network to a PC.
Really will be a Win PC the AP. -sorry-
Please once more: where is the location of the file 'edison_env' ?
Best regards
Achim
Community Manager
Hello Achim,
I understand that you are testing a new setup, with the Edison board as access point, with the Android devices working as clients. You say that this setup is working fine.
Which guide are you following? Is the 'edison_env' file needed for your new AP setup? Have you started the wpa_supplicant to use the wpa_cli (as stated here http://www.intel.com/content/dam/support/us/en/documents/edison/sb/edison_wifi_331438001.pdf http://www.intel.com/content/dam/support/us/en/documents/edison/sb/edison_wifi_331438001.pdf, section 4.2)?
This guide may help you find 'edison.env' (under Modifying the source files): http://drejkim.com/blog/2014/11/22/building-an-edison-image-and-changing-the-root-partition-size/ http://drejkim.com/blog/2014/11/22/building-an-edison-image-and-changing-the-root-partition-size/.
Andres
JJoac3
Hello Andres,
For the design of the connection edison <--> android tablet I have used several documents and examples.
The documents you recommended were also helpful.
Here are some snippets: (it's running on my hardware)
(for remembering: simple UDP Connection between Intel Edison and Android tablet, Edison is now AP)
Edison - part ( Eclipse Platform Version: Luna SR2 (4.4.2))
main(int argc, char **argv)
struct sockaddr_in myaddr; // edison address
struct sockaddr_in remaddr; // remote address
socklen_t addrlen = sizeof(remaddr); // length of addresses
int recvlen; // bytes received
int serversocket; // socket edison - is server
unsigned char buf[BUFSIZE]; // receive buffer
unsigned char buf2[BUFSIZE]; // sendbuffer
string returnString = "Edison is listening to you"; // return_message
// create a UDP socket
if ((serversocket = socket(AF_INET, SOCK_DGRAM, 0)) < 0) {
printf("cannot create socket\n");
return 0;
printf("Socket open\n");
// bind the socket
memset((char *)&myaddr, 0, sizeof(myaddr));
myaddr.sin_family = AF_INET;
myaddr.sin_addr.s_addr = inet_addr("192.168.42.1"); // edison IP
myaddr.sin_port = htons(PORT);
if (bind(serversocket, (<sp...
Community Manager
Hello Achim,
I'm glad you found the documents provided useful.
Now that I have a better understanding of your setup, are you experiencing any issue? Is there anything I can assist you with? What part of your setup is missing?
Andres
