Intel® Makers
9881 Discussions
How to connect Intel Galileo to internet using GPRS module?
MBHAR1
Hello folks,
I am using these commands to connect my intel galileo to 3G internet using gprs module of LINL SPRITE ATwin. I able to run the commands till cgdcont,
I am using the following commands to connect to the internet.
# include
char data[256];
void setup()
Serial1.begin(115200);
Serial.begin(9600); // the GPRS baud rate
delay(1000);
void loop()
if (Serial.available())
switch(Serial.read())
case 't':
SendTextMessage();
break;
case 'd':
DialVoiceCall();
break;
case 'g':
activateGPRS();
break;
if (Serial1.available())
Serial.write(Serial1.read());
void SendTextMessage()
Serial1.print("AT+CMGF=1\r"); //Because we want to send the SMS in
delay(1000);
Serial1.println("AT+CMGS=\"+919148434113\"");
delay(1000);
Serial1.write("Hello from Galileo?");
delay(1000);
Serial1.println((char)26); //the ASCII code of the ctrl+z is 26 (0x1A)
delay(1000);
Serial1.println();
void DialVoiceCall()
Serial1.println("ATD +919148434113;");//dial the number
delay(100);
Serial1.println();
void ShowSerialData()
while(Serial1.available()!=0)
void activateGPRS()
Serial1.println("AT+CPIN?"); // Is SIM ready to use?
delay(1000);
ShowSerialData();
Serial1.println("AT+CGREG?"); // Is device registered?
delay(1000);
ShowSerialData();
Serial1.println("AT+COPS?"); // Does SIM info match network?
delay(1000);
ShowSerialData();
Serial.println("Check signal quality");
Serial1.println("AT+CSQ"); // Check signal quality
delay(1000);
ShowSerialData();
Serial1.println("AT+cgatt=1"); // GPRS attach// define a PDP context with IP connection, ID is 1
Serial1.println("AT+CGDCONT=1,\"IP\",\"internet\"");
delay(1000);
ShowSerialData();
//list PDP contexts that are defined
Serial1.println("at+cgdcont?");
delay(3000);
ShowSerialData();
// setup the session using the appropriate PDP context
Serial1.println("AT+CGACT=1,1");
delay(1000);
ShowSerialData();
Serial.println("session is setup delay 5 seconds");
delay(5000);
Serial1.println("AT+CGQMIN=?");
delay(1000);
ShowSerialData();
Serial1.println("AT+CGQREQ=?");
delay(1000);
ShowSerialData();
Serial1.println("AT+CGACT");
delay(1000);
ShowSerialData();
I am also attaching the response of all the commands which I had got, I am getting OK response till the command cgdcont, after that ERROR is there.
Community Manager
Hi Malvika_bhardwaj,
I would love to help you with this.
I think you should take a look to the http://www.intel.com/content/www/us/en/support/boards-and-kits/000020775.html Shield Testing Report for Intel® Galileo Board, Intel® Galileo Gen 2 Board, and Intel® Edison Board, I'm not sure if your module is the 23 of the list but you can check it.
You can also use the sketch that is in there as reference for your code.
I hope you find this information helpful.
-Leonardo
Community Manager
Do you have any updates about this? Was the information helpful?
Have a nice day!
-Leonardo
MBHAR1
Hello Sir,
With the help of these AT commands, I am able to activate my GPRS module. I want to send data through GPRS to THINKSPEAK server, what are the commands which will be used?
I am also attaching the code and the response of the link which you had send me earlier.
# include
char data[256];
void setup()
Serial1.begin(11500);
delay(1000);
void loop()
case 't':
SendTextMessage();
break;
case 'g':
GPRS();
break;
Serial1.print("AT+CMGF=1\r"); //Because we want to send the SMS in text mode
delay(1000);
delay(1000);
Serial1.println("Hello from Galileo?");
delay(1000);
delay(1000);
Serial1.println();
void GPRS()
delay(1000);
ShowSerialData();
delay(1000);
ShowSerialData();
delay(1000);
ShowSerialData();
delay(1000);
ShowSerialData();
delay(1000);
ShowSerialData();
delay(1000);
ShowSerialData();
// list PDP contexts that are defined
delay(3000);
ShowSerialData();
delay(1000);
ShowSerialData();
delay(5000);
// deactivate the PDP context
Serial1.println("AT+CGACT=0,1");
delay(1000);
ShowSerialData();
// detach from GPRS newtork
Serial1.println("AT+CGATT=0");
delay(1000);
ShowSerialData();
Response of the above code is....
AT+CPIN?
+CPIN: READY
OK
AT+CGREG?
+CGREG: 0,1
OK
AT+COPS?
+COPS: 0,0,"Spice Telecom"
OK
AT+CSQ
+CSQ: 25,99
OK
AT+cgatt=1
OK
AT+CGDCONT=1,"IP","internet"
OK
at+cgdcont?
+CGDCONT: 1,"IP","internet","",0,0
OK
AT+CGACT=1,1
OK
AT+CGACT=0,1
OK
AT+CGATT=0
OK
Community Manager
Thanks for letting us know, about how to send data to ThingSpeak server, I'm not familiarized with that cloud, and I didn't find any helpful information, so I think you should contact https://thingspeak.com/ for a better support.
Have a nice day.
-Leonardo
MBHAR1
Hello Sir,
I have run a code to access data through GPRS, but I am unable to get the response of command "AT+CREG".
Kindly help me out.
int8_t answer;
int onModulePin=2;
char aux_str[100];
char pin[]="1234";
char apn[]="Internet";
char user_name[]=" ";
char password[]=" ";
char IP_address[]="*******";
char port[]="8080";
char ip_data[40]="Test string from GPRS shield\r\n";
void setup(){
pinMode(onModulePin, OUTPUT);
Serial.begin(115200);
Serial.println("Starting...");
void power_on();
delay(3000);
//sets the PIN code
snprintf(aux_str, sizeof(aux_str), "AT+CPIN=%s", pin);
sendATcommand(aux_str, "OK", 2000);
delay(3000);
Serial.println("Connecting to the network...");
while(sendATcommand2("AT+CREG?", "+CREG: 0,1", "+CREG: 0,5", 1000)== 0 );
void loop()
// Selects Single-connection mode
if (sendATcommand2("AT+CIPMUX=0", "OK", "ERROR", 1000) == 1)
// Waits for status IP INITIAL
while(sendATcommand("AT+CIPSTATUS", "INITIAL", 500) == 0 );
delay(5000);
snprintf(aux_str, sizeof(aux_str), "AT+CSTT=\"%s\",\"%s\",\"%s\"", apn, user_name, password);
// Sets the APN, user name and password
if (sendATcommand2(aux_str, "OK", "ERROR", 30000) == 1)
// Waits for status IP START
while(sendATcommand("AT+CIPSTATUS", "START", 500) == 0 );
delay(5000);
// Brings Up Wireless Connection
if (sendATcommand2("AT+CIICR", "OK", "ERROR", 30000) == 1)
// Waits for status IP GPRSACT
while(sendATcommand("AT+CIPSTATUS", "GPRSACT", 500) == 0 );
delay(5000);
// Gets Local IP Address
if (sendATcommand2("AT+CIFSR", ".", "ERROR", 10000) == 1)
// Waits for status IP STATUS
while(sendATcommand("AT+CIPSTATUS", "IP STATUS", 500) == 0 );
delay(5000);
Serial.println("Opening TCP");
snprintf(aux_str, sizeof(aux_str), "AT+CIPSTART=\"TCP\",\"%s\",\"%s\"", IP_address, port);
// Opens a TCP socket
if (sendATcommand2(aux_str, "CONNECT OK", "CONNECT FAIL", 30000) == 1)
Serial.println("Connected");
// Sends some data to the TCP socket
sprintf(aux_str,"AT+CIPSEND=%d", strlen(ip_data));
if (sendATcommand2(aux_str, ">", "ERROR", 10000) == 1)
sendATcommand2(ip_data, "SEND OK", "ERROR", 10000);
// Closes the socket
sendATcommand2("AT+CIPCLOSE", "CLOSE OK", "ERROR", 10000);
else
Serial.println("Error opening the connection");
else
Serial.println("Error getting the IP address");
else
Serial.println("Error bring up wireless connection");
else
Serial.println("Error setting the APN");
else
Serial.println("Error setting the single connection");
sendATcommand2("AT+CIPSHUT", "OK", "ERROR", 10000);
delay(10000);
void power_on()
uint8_t answer=0;
// checks if the module is started
answer = sendATcommand("AT", "OK", 2000);
if (answer == 0)
{// power on pulse
digitalWrite(onModulePin,HIGH);
delay(3000);
digitalWrite(onModulePin,LOW);
// waits for an answer from the module
while(answer == 0){ // Send AT every two seconds and wait for the answer
int8_t sendATcommand(char* ATcommand, char* expected_answer, unsigned int timeout)
uint8_t x=0, answer=0;
char response[100];
unsigned long previous;
memset(response, '\0', 100); // Initialize the string
delay(100);
while( Serial.available() > 0) Serial.read(); // Clean the input buffer
Serial.println(ATcommand); // Send the AT command
x = 0;
previous = millis();
// this loop waits for the answer
do{
if(Serial.available() != 0)
// if there are data in the UART input buffer, reads it and checks for the asnwer
response[x] = Serial.read();
//Serial.print(response[x]);
x++;
// check if the desired answer is in the response of the module
if (strstr(response, expected_answer) != NULL)
answer = 1;
// Waits for the asnwer with time out
while((answer == 0) && ((millis() - previous) < timeout));
return answer;
int8_t sendATcommand2(char* ATcommand, char* expected_answer1,
char* expected_answer2, unsigned int timeout){
char response[100];
delay(100);
while( Serial.available() > 0) Serial.r...
Community Manager
Unfortunately we don't have this shield with us to do some test and help you, but I think that you can contact the author of the library to help you in a better way, or contact LinkSprite.
I found this wiki that can be helpful for you: http://linksprite.com/wiki/index.php5?title=ATWIN_Quad-band_GPRS/GSM_Shield_for_Arduino
Have a nice day.
-Leonardo
