Intel® Makers
9881 Discussions
How to connect/configure usb bluetooth dongle to Galileo Gen 2 ?
ARAVIND_P_Intel
I am just a beginner in IoT world. I want to stream data from my program to android phone via bluetooth.
I have a Bluetooth USB dongle. I am not able to find good documentation about how to configure bluetooth dongle ?
I am using "Enter Bluetooth USB Dongle"
Thanks in advance.
Aravind Putrevu
Sergio_A_Intel
First you'd need to have the dongle recognized by your system. You'd need to download the driver and install it. Make sure your device is recognized using lsusb. As an example you can check . This thread has steps used to enable a WiFi dongle that should guide you through the basic commands needed to install the driver and make the dongle recognizable. The driver and some package names might be different so you'd have to look for the proper driver for your device.
Hopefully this will get you started. After enabling the dongle you can continue on how to configure the android phone functionality.
Sergio
ARAVIND_P_Intel
Thank you. Will try and let you know
