Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
How to connect to Wifi network?
Jump to solution
I am new to the Galileo board. How do i connect to a wifi network ?
What do i need to do if I have to run any examples of Adruino Yun on Galileo?
-Pawan
Tags (2)
Accepted Solutions
Highlighted
Community Manager
Re: How to connect to Wifi network?
Jump to solution
Highlighted
Community Manager
1 View
Jump to solution
Highlighted
Valued Contributor I
Jump to solution
Bookmark Sergey's blog - he has more useful information on the Galileo than you will find anywhere else.
Not just on connecting to WiFi - how to build a serial cable, how to build a full Linux image, and a lot more.
Highlighted
Jump to solution
To try and answer the second half of the question...
I have not used a Yun, but I would imaging that porting from Yun to Galileo will be non-trivial. They are in no way the same thing.
Both run a version of Linux. Both can run Arduino sketches, though in a VASTLY different way. That is about all of the similarities.
Yun has an Arduino device (ATmega32u4) that is connected to a MIPS based processor that runs a version of Linux. It also has WiFi built in and has (at least from what I hear) great development environment.
Galileo is an x86 processor that runs a Linux version that also EMULATES an Arduino device. The sketch you make for Galileo is actually a Linux executable that runs just like any other process. This means the process can be pre-empted by other processes, which means your sketch will not be 100% timing accurate. The Galileo can also connect to WiFi, for a small price (cost of mPCIe WiFi card, and antennas). However, I think it would be accurate to say the development environment is not as robust as the Yun's.
