I want to modify some functions in the kernel and cross re-compile it in Ubuntu.How shall I do this?
I found some reference for how to compile but unable to find the source code .
Could you please provide the source code for latest kernel it support Wi-Fi,BT,I2C,SPI,UART.
Reference links(no source code)
https://software.intel.com/en-us/node/593591 IoT - Build an Intel® Edison Image using bitbake | Intel® Software
https://software.intel.com/en-us/node/593592 IoT - Creating Custom Intel® Edison Images | Intel® Software
Only I found the source code along with process.
http://www.hackgnar.com/2016/01/manually-building-yocto-images-for.html hackgnar: Manually Building Yocto Images for the Intel Edison Board from Source
Thank you
Srinivas
The source of the latest Edison image release can be found here https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads under Intel® Edison Board Firmware Software Release 3.5.
Follow the guides previously mentioned and let us know your results.
-Sergio
Hi Sergio ,
We can't find the source for 3.5 release. Only binary are available.
we are using https://downloadcenter.intel.com/download/25871 Download Intel® IoT Developer Kit Installer Files this link.
I need complete source code(kernel,bsp,uboot).
Please do need full.
Take a look at http://iotdk.intel.com/src/3.5/edison/ http://iotdk.intel.com/src/3.5/edison/ . You can see the steps you need to follow in the README inside this file.
Let us know if this is what you were looking for.
-Sergio
