Intel® Makers
9881 Discussions
How to do a hard reset( factory reset) with the Intel Edison board?
OJinn
is there any steps or ways i can factory reset (as in clear everything away) from inside the Edison board?
Any help is much appreciated. Thank you
Jinnie
Diego_V_Intel
Hello Jinnie,
A factory reset would be to re-flash the Edison module. This way you would be flashing the Edison with a new image and the packages that you had installed would be erased. You can re-flash the Edison using the Flash Tool Lite. This software can be downloaded from the following site, under the Flash Tool Lite section: https://software.intel.com/en-us/iot/hardware/edison/downloads IoT - Intel® Edison Board Download | Intel® Developer Zone
Diego.
Diego_V_Intel
Hello Jinnie,
Diego.
OJinn
Hi DiegoV,
Thank you for your response. I'll try it out . Thanks
Jinnie
