Intel® Makers
9874 Discussions
How to enable CGI module of lighttpd server on Galileo
YZhan71
【English - 英文】
I have a problem on using CGI of lighttpd of yocto linux on Galileo.
I have installed the yocto linux on SD card and boot Galileo from it, and I have a CGI test program written in Python located in /www/pages/cgi
print("Content-type:text/html\n\n")
print('')
print('')
print('')
print('')
print('Hello, World!')
print('')
print('')
and I have change its mode:
chmod 755 test.py
In order to enable the CGI module, I modified file /etc/lighttpd.conf like this:
server.modules = (
"mod_cgi",
(I deleted the '# ' before "mod_cgi" to enable it)
However, after rebooting Galileo, I typed the address of CGI program for example:
http://192.168.0.4:80/cgi/test.py http://192.168.0.4:80/cgi/test.py
"403 - Forbidden" is displayed on browser.
It doesn't work.
Seems that the CGI module of lighttpd is not exist...
How can I enable the CGI module of lighttpd?
Need I compile the whole OS to enable the CGI module of lighttpd?
【Chinese - 中文】
大家过年好~
我在SD卡里面烧写了官方提供的yocto linux,
并且用Python写了一段测试用的CGI程序,位于/www/pages/cgi,代码如下:
print('')
print('')
print('')
print('')
print('')
print('')
赋予其可执行权限:
chmod 755 test.py
我想使用Python编写的CGI程序去处理POST/GET请求,因此修改配置文件/etc/lighttpd.conf如下:
server.modules = (
"mod_cgi",
(删除了注释)
但重启Galileo板子之后,浏览器访问这个py脚本,会提示"403-Foridden",反正就是跑不起来……
感觉官方提供的Yocto镜像根本就没有CGI模块啊……
所以我想问问大家,如何启用lighttpd的CGI模块?是不是需要从头开始编译系统?
谢谢~
(论坛里如果有懂汉语的朋友我们可以认识一下o(^▽^)o)
YZhan71
【English - 英文】
I have solved this problem by myself...
The CGI module was not installed in yocto linux. So I installed it and enabled it. Very easy.
In order to download software needed, I bought a wlan adapter "Intel Corporation Centrino Advanced-N 6205 AGN" and enabled Wi-Fi connection following the instructions provided by this page: https://software.intel.com/en-us/node/519955 IoT - Connecting to a Wi-Fi Network | Intel® Software
After establishing connection to Internet, Input command line
opkg install lighttpd-module-cgi
and wait.
Modify the configuration file of lighttpd /etc/lighttpd.conf like that:
server.modules = (
"mod_cgi",
static-file.exclude-extensions = ( ".php", ".pl", ".fcgi", ".py" )
cgi.assign = ( ".pl" => "/usr/bin/perl",
".cgi" => "/usr/bin/perl",
".py" => "/usr/bin/python" )
I modified the port number of lighttpd to 81 for convenience.
Type and execute the command:
lighttpd -f /etc/lighttpd.conf
I make a directory /www/pages/cgi-bin and put test.py in it. The content of test.py is
# !/usr/bin/env python
# -*- coding: utf-8 -*-
import commands
import cgi
import os
print('Content-Type:text/html\n\n')
print('"')
print('CGI TEST / CGI测试')
print('
by mikukonai@IntelCommunity
print('')
print('
Shell Command Test: Reading BMP280 Barometer
print('
以下是Shell命令执行测试:读取BMP280传感器返回的气压数据
print( commands.getoutput('/home/root/bmp280/bmp280_pressure') )
Test it, and It works!
Hope this helps to anyone in need
【Chinese - 中文】
最后我自己解决了这个问题……其实很简单,CGI模块没有安装而已。
淘宝上买了一块网卡,型号是 Centrino Advanced-N 6205 AGN,按照这个页面 https://software.intel.com/en-us/node/519955 IoT - Connecting to a Wi-Fi Network | Intel® Software 的说明联网。
联网后执行如下命令,安装cgi模块:
修改配置文件 /etc/lighttpd.conf 如下,以启用CGI:
server.modules = (
"mod_cgi",
为了方便我把lighttpd的端口改成了81。(因为我不知道如何重启lighttpd(捂脸哭))
载入修改后的配置文件:
新建目录 /www/pages/cgi-bin 并将 test.py 置于其中,代码如下:
import commands
import cgi
import os
print('"')
print('
print('')
print('
print('
测试,成功!
希望能帮到您
FTinetti
Honored Contributor I
Hi mikukonai,
I've not used lighttpd-python CGI, I've used an "only-python" setting:
a) start a python web server with CGI enabled, with the command line:
python -m CGIHTTPServer > pythonsrvr.out 2> pythonsrvr.err &
b) use it
Please let me know in case these instructions are not complete enough for you, I can try to make a small complete example.
HTH,
Fernando.
YZhan71
Thank you very much.
I referred other documentations such as https://docs.python.org/2.7/library/cgihttpserver.html 20.20. CGIHTTPServer — CGI-capable HTTP request handler — Python 2.7.13 documentation
I tried it and managed to start the server with CGI.
But I still don't know how to enable CGI module of lighttpd
CGIHTTPServer has a worse performance than other servers.
YZhan71
【English - 英文】
and wait.
server.modules = (
"mod_cgi",
import commands
import cgi
import os
print('"')
print('
print('')
print('
print('
【Chinese - 中文】
联网后执行如下命令,安装cgi模块:
server.modules = (
"mod_cgi",
载入修改后的配置文件:
import commands
import cgi
import os
print('"')
print('
print('')
print('
print('
测试,成功!
希望能帮到您
