Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
How to enable/use i2c?
Jump to solution
Can someone clarify exactly the steps necessary to use i2c on the Edison with Arduino dev board? Is there documentation somewhere that I missed? I'm using the A4/A5 pins on the Arduino board and my sensor (HTU21D-F) is not detected. My understanding is that this corresponds to i2c-6 and that i2c-1 is disabled. Any help would be appreciated. I'm novice, so forgive me if there's not enough detail.
root@edison:~# i2cdetect -y -r 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- UU UU UU -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
root@edison:~# i2cdetect -y -r 6
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
Accepted Solutions
Highlighted
Hi slastname,
If you are using the board from the Arduino side I will suggest you to take a look at the sketch I attached to this post. It is an I2C scanner. I tested it connecting the Edison Arduino board to an Arduino UNO and to a LCD shield too, and it works.
From Linux side, you could use Python. Here is an example of using I2C from Python: https://github.com/MakersTeam/makers-examples/blob/master/Python-Examples/I2Ctest.py makers-examples/I2Ctest.py at master · MakersTeam/makers-examples · GitHub
If you are using I2C from Linux shell, you have to make sure all the mux settings are set correctly. To see more details about the mux settings, please check this page: http://www.emutexlabs.com/project/215-intel-edison-gpio-pin-multiplexing-guide EmutexLabs
Let me know if this answered your question. I hope you find this information useful.
Diego.
Highlighted
Hi slastname,
Diego.
Highlighted
That is an excellent resource (http://www.emutexlabs.com/project/215-intel-edison-gpio-pin-multiplexing-guide EmutexLabs), thanks!
Highlighted
Community Manager
Hi Diego,
Do you have a scanner that scan i2C1 and i2C6 because your programm seems to works only on i2c6.
Thank you
Paul
